Curtain Enclosure
aodhan
Curtain Enclosure
Post by aodhan »
If you're not concerned about containing a large percentage of particulate coming off of your printer, you can opt for my low cost enclosure solution.
The curtain enclosure:
Overall photo
Overall photo
The curtains each measure 28" x 15.5" and are cut from pleather that I had hanging around the house. I would guess that most fabric you have hanging around would work similarly enough.
Iso view installed
Iso view installed
The fabric is inserted in the small clamp on the back of the curtain clip and the clip is simply slid on the plate at the edge of the build area.
Side view installed
Side view installed
Here's the clip model:
Curtain Clips Rev C.stl
Curtain Clip STL
(546.84 KiB) Downloaded 282 times
Re: Curtain Enclosure
I like it! It's a lot cleaner than my canvas-and-binder-clips version. :)
Return to “RostockMAX v3”
