Orion will not home
Kevinvandeusen
Orion will not home
Someone came in my store today, and decided to play with the lcd controls. Now when you ask to home, it just goes down about 25mm. I am baffled as to what they must have changed?
Re: Orion will not home
I think they set a new Z height at an absurd value. Try resetting it to a sensible value.
*not actually a robot
- briankb
I'm having this issue right now and it was because I accidentally pressed on the "Set Z Height" menu item. I have tried, what I thought would correct it, but it still only goes DOWN when I press Home. I would expect it to go UP when I ask it to home until it hits each of the switches.
What I've tried to no avail:
- manually move the hot end tip to just above the center of glass and resetting Z Height via same menu that got it messed up in first place.
- tried running Calibration which I assume would just ignore existing settings and start from scratch.
You could reset the z height in the eeprom( it's probably showing a weird number) to approximately the right value and then go ahead and then calibrate the z height normally.
- briankb
Isn't that what the LCD Menu "Set Z Height" does? I tried that a few times to no avail.joe wrote:You could reset the z height in the eeprom( it's probably showing a weird number) to approximately the right value and the go ahead and then calibrate the z height normally.
Sorry, forgot to mention the you should do it in the eeprom first THEN use the LCD menu.briankb wrote:Isn't that what the LCD Menu "Set Z Height" does? I tried that a few times to no avail.joe wrote:You could reset the z height in the eeprom( it's probably showing a weird number) to approximately the right value and the go ahead and then calibrate the z height normally.
- briankb
That worked. thanks Joe!!!!joe wrote:Sorry, forgot to mention the you should do it in the eeprom first THEN use the LCD menu.
Sweet. You are most welcome.
- tomcapizzi
- Plasticator
By saying: "You could reset the z height in the EEPROM ( it's probably showing a weird number) to approximately the right value and the go ahead and then calibrate the z height normally." You are saying that I should re-send the Repetier config file back to EEPROM?
My menu selection on the Orion console for EEPROM settings are "Store to EEPROM" and "Load from EEPROM", I have wiped the EEPROM and resent the config file numerous times back to the RAMBo board with no change in results. When I home the printer, the head lowers about 1", and it will not configure Z height correctly.
have you found a solution? having the same problem
- pouncingiguana
The easy way to fix the problem (assuming you've got the newer hot end with the probe) is to connect with MatterControl (or whatever) and open a terminal. Run M502, M500, G29. This will reset the EEProm to stock values, Save, then calibrate to set your endstops, z height, and horizontal radius.
