Rostock Max V2 to V3 troubles
latif
Re: Rostock Max V2 to V3 troubles
Post by latif »
Hi guys,
I haven't been using my Rostock max v2 upgraded with a new fancy hotend with the probe thingy for probably a few weeks now cause I was building an enclosure for it.
It's cold in my basement and I wanted to protect it a little better.
So you guessed it I had to move it around a little bit but I wasn't worried cause I have the accelerometer probe so it should be good, not!
So I run g28 and then g29 and all the hot-end does is smash into the plate when it gets to the first tower and then does it over and over again.
Now I read the thread and tried lowering the z-height and stuff but no dice so far and you can probably guess from my tone that I'm a little frustrated.
Why is the hot-end crashing into the plate? isn't it what the probe was supposed to avoid.
I was really excited to finally not have to spend 30 minutes before every big print on my knees with a piece of paper squinting my eyes and trying to be as gentle as possible with the machine but now I just want to .... whatever
Any tips guys before I put it on craigslist?
Make sure the cable connecting to the HE280 hasn't come partially loose. Also check your wiring for the HE280 to ensure that it's correct.
Return to “Mods and Upgrades”
