I have a probleb with rambo ver 1.2
When i turned the board on (Pluged the powers) green led lits up after that all the red lights lit up without any control.
turned it on all the red lights lit up
NaderHatami
- Noob
- U.S. Water Rockets
Re: turned it on all the red lights lit up
You should try to load the repetier software, then check the LED behavior. Maybe some other program is loaded that's turning stuff on.
Have you fix the problem? How exactly did you get rid off the RED LED on Rambo board?
