Does bed heat on first power up?
sandcrab3
Post by sandcrab3 »
The first time that you turn on power before any firmware is installed, does the bed heat? Just wondering if this is normal, or a problem.
MAX V3 and Robo 3D R1 Plus
Simplify 3D Software is my choice.
Re: Does bed heat on first power up?
No, it should not heat up until you tell it to either by running a print or entering a bed temperature in the controller. If it is heating as soon as you turn the bed on, you have a wiring or other problem.
Return to “RostockMAX v3”
