H2 Hacker Z axis not moving...
Fe_Lantern
Post by Fe_Lantern »
Recently was very fortunate and won a H2 Delta Hacker kit. While I do own two Robo3d R1+ machines, this is my first 3d printer kit. I have it all built and the Repetier firmware loaded into the mini-RAMBo to the best of my ability. While everything else appears to be working I have found that my Z-axis will not move by itself. When I tried to calibrate the printer Both the X and Y will move and attempt to drag the Z axis.
Looking for possible solutions, I did find out to check if the Z-axis stepper was a dud or not, I have swapped the Z-axis with another axis on the mini-RAMBo board and it functioned normally, while the other axis did not. So it is either a board issue or a firmware issue. I am attempting to find a fault/error it the firmware, but this is all fresh to me and I am not certain what to look for. Most troubleshooting threads I have seen were dealing with a inverted, but still moving Z-axis, or were on different machines.
Printer Model List as used throughout this firmware
Orion            = 1
Rostock Max V2   = 2
ERIS             = 3
Rostock MAX v3   = 5
Hacker H2        = 6
// ### Define your Printer Model here! ###
#define PRINTER 6
// SeeMeCNC Bowden w/PEEK barrel = 1
// HE240 on ERIS w/accel probe   = 2
// HE280 w/accel probe           = 3
#define HOTEND 3
// ### Define your motherboard here! ###
// 301 = RAMBo    302 = MINI RAMBo
#define MOTHERBOARD 302
// ##### Older Orions w/ATX had Y inverted and NEW PSU on orions needs opposite ###
// 1 = ATX on older machines  2 = Rail style PSU on newer machines ############################
#define POWER_SUPPLY 2
// ### Number of active extruders
// 1 is standard, 2 is with the Y coupler for dual filament input
#define NUM_EXTRUDER 1
#elif PRINTER == 6  // Hacker H2
#if MOTHERBOARD == 301
#if NUM_EXTRUDER == 1
#define MOTOR_CURRENT {140,140,140,130,0}
#elif NUM_EXTRUDER == 2
#define MOTOR_CURRENT {140,140,140,145,145}
#endif
#elif MOTHERBOARD == 302
#define MOTOR_CURRENT_PWM {100, 100, 130}
#endif
#define EXT0_PID_INTEGRAL_DRIVE_MAX 180
#define EXT0_PID_INTEGRAL_DRIVE_MIN 80
#define EXT0_PID_PGAIN_OR_DEAD_TIME 14.50
#define EXT0_PID_I 0.73
#define EXT0_PID_D 53.41
#define EXT0_PID_MAX 255
#define INVERT_X_DIR 1
#define INVERT_Y_DIR 1
#define INVERT_Z_DIR 1
#define DELTA_DIAGONAL_ROD 178.0  // ball cup arms
#define DELTA_MAX_RADIUS 72.0
#define PRINTER_RADIUS 155.0
#define Z_MAX_LENGTH 295.0
#define END_EFFECTOR_HORIZONTAL_OFFSET 30.22
#define CARRIAGE_HORIZONTAL_OFFSET 26.5  // molded cheapskates
#define DELTASEGMENTS_PER_PRINTLINE 22
#define STEPPER_INACTIVE_TIME 600L
#define MAX_INACTIVE_TIME 900L
#define MAX_FEEDRATE_X 250
#define MAX_FEEDRATE_Y 250
#define MAX_FEEDRATE_Z 250
#define HOMING_FEEDRATE_X 80
#define HOMING_FEEDRATE_Y 80
#define HOMING_FEEDRATE_Z 80
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 1850
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 1850
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 1850
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 3000
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 3000
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 3000
#define MAX_JERK 32
#define MAX_ZJERK 32
#define FEATURE_Z_PROBE 1
#define Z_PROBE_SENSITIVITY  20 // 0-126 7 bit value
#define Z_PROBE_BED_DISTANCE 20
#define Z_PROBE_PULLUP 1
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_WAIT_BEFORE_TEST 0
#define Z_PROBE_SPEED 80
#define Z_PROBE_XY_SPEED 50
#define Z_PROBE_SWITCHING_DISTANCE 10
#define Z_PROBE_REPETITIONS 1
#define Z_PROBE_HEIGHT -0.1
#define Z_PROBE_START_SCRIPT "G28/nG1Z25/n"
#define Z_PROBE_FINISHED_SCRIPT ""
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 -75.933
#define Z_PROBE_Y1 -43.84
#define Z_PROBE_X2 75.933
#define Z_PROBE_Y2 -43.84
#define Z_PROBE_X3 0
#define Z_PROBE_Y3 87.69
#define SDSUPPORT 1
#define SDCARDDETECT 81
#define SDCARDDETECTINVERTED 0
#define UI_PRINTER_NAME "Hacker H2"
#define HAVE_HEATED_BED 0
#define FEATURE_CONTROLLER 13
#endif
#define FEATURE_RETRACTION 0
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 3
#define RETRACTION_LONG_LENGTH 13
#define RETRACTION_SPEED 40
#define RETRACTION_Z_LIFT 0
#define RETRACTION_UNDO_EXTRA_LENGTH 0
#define RETRACTION_UNDO_EXTRA_LONG_LENGTH 0
#define RETRACTION_UNDO_SPEED 20
#define FILAMENTCHANGE_X_POS 0
#define FILAMENTCHANGE_Y_POS 0
#define FILAMENTCHANGE_Z_ADD  2
#define FILAMENTCHANGE_REHOME 1
#define FILAMENTCHANGE_SHORTRETRACT 5
#define FILAMENTCHANGE_LONGRETRACT 50
#define RETRACT_DURING_HEATUP true
#define PID_CONTROL_RANGE 20
#define SKIP_M109_IF_WITHIN 5
#define SCALE_PID_TO_MAX 0
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 1000
#define NUM_TEMPS_USERTHERMISTOR0 0
#define USER_THERMISTORTABLE0 {}
#define NUM_TEMPS_USERTHERMISTOR1 0
#define USER_THERMISTORTABLE1 {}
#define NUM_TEMPS_USERTHERMISTOR2 0
#define USER_THERMISTORTABLE2 {}
#define USE_GENERIC_THERMISTORTABLE_1
#define GENERIC_THERM1_T0 25
#define GENERIC_THERM1_R0 100000
#define GENERIC_THERM1_BETA 4450 //4267
#define GENERIC_THERM1_MIN_TEMP -50
#define GENERIC_THERM1_MAX_TEMP 300
#define GENERIC_THERM1_R1 0
#define GENERIC_THERM1_R2 4700
#define USE_GENERIC_THERMISTORTABLE_2
#define GENERIC_THERM2_T0 25
#define GENERIC_THERM2_R0 100000
#define GENERIC_THERM2_BETA 4367
#define GENERIC_THERM2_MIN_TEMP -20
#define GENERIC_THERM2_MAX_TEMP 300
#define GENERIC_THERM2_R1 0
#define GENERIC_THERM2_R2 4700
#define GENERIC_THERM_VREF 5
#define GENERIC_THERM_NUM_ENTRIES 33
#define HEATER_PWM_SPEED 0
// ################ Endstop configuration #####################
#define ENDSTOP_PULLUP_X_MIN true
#define ENDSTOP_X_MIN_INVERTING false
#define MIN_HARDWARE_ENDSTOP_X false
#define ENDSTOP_PULLUP_Y_MIN true
#define ENDSTOP_Y_MIN_INVERTING false
#define MIN_HARDWARE_ENDSTOP_Y false
#define ENDSTOP_PULLUP_Z_MIN true
#define ENDSTOP_Z_MIN_INVERTING true
#define MIN_HARDWARE_ENDSTOP_Z false
#define ENDSTOP_PULLUP_X_MAX true
#define ENDSTOP_X_MAX_INVERTING false
#define MAX_HARDWARE_ENDSTOP_X true
#define ENDSTOP_PULLUP_Y_MAX true
#define ENDSTOP_Y_MAX_INVERTING false
#define MAX_HARDWARE_ENDSTOP_Y true
#define ENDSTOP_PULLUP_Z_MAX true
#define ENDSTOP_Z_MAX_INVERTING false
#define MAX_HARDWARE_ENDSTOP_Z true
#define max_software_endstop_r true
#define min_software_endstop_x false
#define min_software_endstop_y false
#define min_software_endstop_z false
#define max_software_endstop_x true
#define max_software_endstop_y true
#define max_software_endstop_z true
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 5
#define ENDSTOP_X_RETEST_REDUCTION_FACTOR 2
#define ENDSTOP_Y_RETEST_REDUCTION_FACTOR 2
#define ENDSTOP_Z_RETEST_REDUCTION_FACTOR 2
#define ENDSTOP_X_BACK_ON_HOME 5
#define ENDSTOP_Y_BACK_ON_HOME 5
#define ENDSTOP_Z_BACK_ON_HOME 5
#define ALWAYS_CHECK_ENDSTOPS 1
// ################# XYZ movements ###################
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
// ######   Inverting Axis Settings for Orion/Rostock MAX v2/DropLit
#define X_HOME_DIR 1
#define Y_HOME_DIR 1
#define Z_HOME_DIR 1
#define X_MAX_LENGTH 250
#define Y_MAX_LENGTH 250
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
// ###   Distortion correction for bed mapping ###
#define DISTORTION_CORRECTION 0
#define DISTORTION_CORRECTION_POINTS 5
#define DISTORTION_CORRECTION_R 100
#define DISTORTION_PERMANENT 1
#define DISTORTION_UPDATE_FREQUENCY 15
#define DISTORTION_START_DEGRADE 0.5
#define DISTORTION_END_HEIGHT 1
#define DISTORTION_EXTRAPOLATE_CORNERS 0
// ##                           Movement settings                                          ##
#define FEATURE_BABYSTEPPING 1
#define BABYSTEP_MULTIPLICATOR 1
#define DELTA_SEGMENTS_PER_SECOND_PRINT 200 // Move accurate setting for print moves
#define DELTA_SEGMENTS_PER_SECOND_MOVE 80 // Less accurate setting for other moves
#define DELTA_ALPHA_A 210
#define DELTA_ALPHA_B 330
#define DELTA_ALPHA_C 90
#define DELTA_RADIUS_CORRECTION_A 0
#define DELTA_RADIUS_CORRECTION_B 0
#define DELTA_RADIUS_CORRECTION_C 0
#define DELTA_DIAGONAL_CORRECTION_A 0
#define DELTA_DIAGONAL_CORRECTION_B 0
#define DELTA_DIAGONAL_CORRECTION_C 0
#define DELTA_HOME_ON_POWER 0
#define STEP_COUNTER
#define DELTA_X_ENDSTOP_OFFSET_STEPS 0
#define DELTA_Y_ENDSTOP_OFFSET_STEPS 0
#define DELTA_Z_ENDSTOP_OFFSET_STEPS 0
#define DELTA_FLOOR_SAFETY_MARGIN_MM 15
#define HOMING_ORDER HOME_ORDER_ZXY
#define ENABLE_BACKLASH_COMPENSATION 0
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 0
#define DIRECTION_DELAY 0
#define STEP_DOUBLER_FREQUENCY 12000
#define ALLOW_QUADSTEPPING 1
#define DOUBLE_STEP_DELAY 1 // time in microseconds
#define MAX_HALFSTEP_INTERVAL 1999
#define PRINTLINE_CACHE_SIZE 16
#define MOVE_CACHE_LOW 10
#define LOW_TICKS_PER_MOVE 250000
#define FEATURE_TWO_XSTEPPER 0
#define X2_STEP_PIN   ORIG_E1_STEP_PIN
#define X2_DIR_PIN    ORIG_E1_DIR_PIN
#define X2_ENABLE_PIN ORIG_E1_ENABLE_PIN
#define FEATURE_TWO_YSTEPPER 0
#define Y2_STEP_PIN   ORIG_E1_STEP_PIN
#define Y2_DIR_PIN    ORIG_E1_DIR_PIN
#define Y2_ENABLE_PIN ORIG_E1_ENABLE_PIN
#define FEATURE_TWO_ZSTEPPER 0
#define Z2_STEP_PIN   ORIG_E1_STEP_PIN
#define Z2_DIR_PIN    ORIG_E1_DIR_PIN
#define Z2_ENABLE_PIN ORIG_E1_ENABLE_PIN
#define FEATURE_DITTO_PRINTING 0
#define USE_ADVANCE 1
#define ENABLE_QUADRATIC_ADVANCE 0
// ################# Misc. settings ##################
#define BAUDRATE 250000
#define ENABLE_POWER_ON_STARTUP 1
#define POWER_INVERTING 0
#define KILL_METHOD 1
#define GCODE_BUFFER_SIZE 2
#define ACK_WITH_LINENUMBER 0
#define WAITING_IDENTIFIER "wait"
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 1
/* ======== Servos =======
Control the servos with
M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
Servos are controlled by a pulse width normally between 500 and 2500 with 1500ms in center position. 0 turns servo off.
WARNING: Servos can draw a considerable amount of current. Make sure your system can handle this or you may risk your hardware!
#define FEATURE_SERVO 0
#define SERVO0_PIN -1
#define SERVO1_PIN -1
#define SERVO2_PIN -1
#define SERVO3_PIN -1
/* #################### Z-Probe configuration and Settings #####################
   These will change machine to machine, be sure to have the correct machine selected in the top of this config file
// 301 = RAMBO    302 = MINI_RAMBO
#define Z_PROBE_PIN 4
#define Z_PROBE_PIN 16
#endif
#define Z_PROBE_TOLERANCE .1
#define Z_PROBE_MAX_SENSITIVITY 40
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
// ##############  SD Card Settings  #########################
#define SD_EXTENDED_DIR 1 /** Show extended directory including file length. Don't use this with Pronterface! */
#define SD_RUN_ON_STOP ""
#define SD_STOP_HEATER_AND_MOTORS_ON_STOP 1
#define ARC_SUPPORT 0
#define FEATURE_MEMORY_POSITION 1
#define FEATURE_CHECKSUM_FORCED 0
#define FEATURE_FAN_CONTROL 1
#define UI_LANGUAGE 1000 // 1000 = User defined language in v92+
#define UI_PRINTER_COMPANY "SeeMeCNC"
#define UI_ENCODER_DIR 1 // 0 normal 1 inverts encoder direction
#define UI_PAGES_DURATION 4000
#define UI_ANIMATION 0
#define UI_SPEEDDEPENDENT_POSITIONING 1
#define UI_DISABLE_AUTO_PAGESWITCH 1
#define UI_AUTORETURN_TO_MENU_AFTER 600000
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 2
#define UI_KEY_BOUNCETIME 10
#define UI_KEY_FIRST_REPEAT 500
#define UI_KEY_REDUCE_REPEAT 50
#define UI_KEY_MIN_REPEAT 50
#define FEATURE_BEEPER 1
#define CASE_LIGHTS_PIN -1
#define CASE_LIGHT_DEFAULT_ON 1
#define UI_START_SCREEN_DELAY 1000
Beeper sound definitions for short beeps during key actions
and longer beeps for important actions.
Parameter is delay in microseconds and the secons is the number of repetitions.
Values must be in range 1..255
#define BEEPER_SHORT_SEQUENCE 1,1
#define BEEPER_LONG_SEQUENCE 32,4
#define UI_SET_PRESET_HEATED_BED_TEMP_PLA 60
#define UI_SET_PRESET_EXTRUDER_TEMP_PLA   180
#define UI_SET_PRESET_HEATED_BED_TEMP_ABS 100
#define UI_SET_PRESET_EXTRUDER_TEMP_ABS   200
#define UI_SET_MIN_HEATED_BED_TEMP  30
#define UI_SET_MAX_HEATED_BED_TEMP 120
#define UI_SET_MIN_EXTRUDER_TEMP   150
#define UI_SET_EXTRUDER_FEEDRATE 2
#define UI_SET_EXTRUDER_RETRACT_DISTANCE 3
#endif
Any assistance/guidance in figuring this out will be greatly appreciated! I want to make this build a succcess
IMBoring25
Re: H2 Hacker Z axis not moving...
Post by IMBoring25 »
Use the gcode console to pass it an M119. An open on the endstop will cause that axis to think the endstop is triggered and it may not move or move only subtly. Just to rule out that possibility...
Fe_Lantern
IMBoring25 wrote:Use the gcode console to pass it an M119. An open on the endstop will cause that axis to think the endstop is triggered and it may not move or move only subtly. Just to rule out that possibility...
Ran it through and it seems to be acting the same
Just a note of printer behavior:
When homing- the X-axis will raise and hit the endstop repeatedly for a couple of seconds, pause, and repeat once. This happens with the Y-axis just an inch or so short of the endstop and the Z-axis is as low as the other two will allow.
IMBoring25
M119 doesn't change anything. It just prints the endstop states to the console. I don't use it often enough to remember the convention, but the states are High or Low and they should all be the same when the endstops are not triggered and reverse when the corresponding endstop is triggered.
Fe_Lantern, that behavior you described sounds like the end stop switches are not plugged into the right axis connectors on the Mini-Rambo.
Pull the carriages away from the top so none of the switches can be hit. Enter M119 at the console. All three should show "L" as their state. If one or more does not, you've either got a short in the wire (unlikely), or you've wired the switch incorrectly (possible).
If all three show "L", then test each switch by holding the switch closed with the end stop screw on the carriage and enter M119 again. The axis that is being activated should show "H". If the axis that shows activation isn't the one being activated, then the end stop switch is plugged into the wrong location on the controller. Do this test for each axis.
Fe_Lantern
IMBoring25 wrote:M119 doesn't change anything. It just prints the endstop states to the console. I don't use it often enough to remember the convention, but the states are High or Low and they should all be the same when the endstops are not triggered and reverse when the corresponding endstop is triggered.
geneb wrote:Fe_Lantern, that behavior you described sounds like the end stop switches are not plugged into the right axis connectors on the Mini-Rambo.
It looks like I somehow managed to switch the X and Y on the board. After putting them in the correct locations, the M119 manual switch test showed everything was okay. It can successfully home, and I have done the initial calibration/level with no troubles. Following the calibration guide at the moment and PID tuning the hot end. Exciting!
The true test will be that first print :)
Much thanks geneb and IMBoring25!
Edit: Oddly enough I can't seem to print yet due to the extruder not allowing itself to drop to printing temperature. Even if I select "shut off all heats" from the printers control screen.
I don't understand what you mean by "drop to printing temperature"...
What's your *exact* process to print a part?
Fe_Lantern
Using MatterControl if I attempt to start a print and the nozzle temperature is above the temperature for the filament in the print operation it remains nearly at its current temperature.
Ex: the LCD and Mattercontrol display a nozzle temp of 227. I start a print via MatterControl and it diplays "waiting for Extruder to Heat to 210." However it never reduces temperature. ( in this case it maintains at 228.3-228.6).
It is worth noting that the displayed starting temperature was 225, which shouldn't be after it was off and had no power.
What does the front panel of the H2 say the nozzle temp is?
Fe_Lantern
When turned on it stated 111, rapidly rose, and has gotten to and fluctuates from 176-178 in varying increments (it did make it up to 190 toward the end of typing this post). This is standalone, with no connection to a computer.
You've got something mis-wired I think. The thermistor should be reading around room temperature - under 30C (unless the room is REALLY warm).
Take care to make sure that the 8 pin connector that goes into the hot end is wired correctly. There's a tiny pin 1 mark on the connector that's just visible in the PDF wiring diagram that JJ made for the dozuki. It could also be that the thermistor leads are shorted against one another - check for that as well.
Fe_Lantern
[img]https://c1.staticflickr.com/5/4232/3488 ... bec2_n.jpg[/img] [img]https://c1.staticflickr.com/5/4230/3523 ... 12aa_n.jpg[/img]
Comparing to the resource diagram, I believe it's all wired in correctly. Even gave the wires a little tug to make sure they were in. Checked the thermistor solder points in the hot-end board and touched them up a bit. There was no apparent shorting/connection but it did look like a cold solder...it has been a while ;) .
Reconnected the hot-end whip, turned it on and waited. The nozzle temperature displayed was 11 to begin and after 10 minutes or so it was maintaining near 39-40.
Briefly after however, while typing this, the LCD screen displayed "killed" at the bottom. After I noticed this and watched the screen the temperature rose slowly at first and jumped exponentially. I turned it off when I saw it display over 200. One step forward and two steps back
I'm glad you posted the photo of the whip connector. I'm pretty sure you've got it backwards.
See this diagram: https://seemecnc.dozuki.com/Document/23/.pdf
You see how in "Detail C" it's showing you that tiny little arrow at the top? That's pin one. From my (admittedly poor) memory, the access holes on the connector are on the "back" face and the tiny arrow is on the "front" face. Since the access holes are facing the camera, I suspect the connector is on backwards. The problem is that I can't be 100% sure because the image isn't large enough to easily identify the pin one marking (which is only one one face of the connector shell).
Fe_Lantern
[img]https://c1.staticflickr.com/5/4232/3512 ... 03f846.jpg[/img]
(A photo with more contrast showing the arrow)
That was the very same "resource diagram", I poorly described :lol: , that I double checked.
With the thermistor better soldered would it be wise to try and "PID Tune the Hot End" again? The one thing that I wasn't clear on in the guide about this process was how many times I should repeat. Is there a change in values that should be observed or an ideal value range for the Kp, Ki, and Kd?
"Auto-Tuning is an iterative process, so run the routine again via the terminal, sending: M303 P0 S235 X0"
Matterhackers also had a guide for PID tuning that differed slightly, sending: M303 E0 S240 C3, entering the values in Mattercontrols EEPROM setting, and making the value permanent by sending M500. But this was just me searching for more details that might make a mental connection. In this world of programming I am certainly out of my depth and I at least know trying to mix different processes will often yield unsatisfactory results.
Or possibly I am putting the cart before the horse, and should take some time over the week end, or free time and go back through the guide and double check everything hardware related.
In some free time however I did take the opportunity to print some pieces for the H2 (on my Robo) and am making it a bit more complete. i.e. not letting the power input, on/ off switch, and LCD screen just dangle( thanks to the files available in the community downloads). Along with a couple of basic top panels and the third, a nameplate :D
[img]https://c1.staticflickr.com/5/4250/35295881435_9d18490cc1.jpg[/img]
Hooray for contrast! ;)
Try this - the connector with the white & green wires are the thermistor leads. Unplug it from the mini-RAMBo and connect a multimeter to the leads and see what resistance you get. It's going to be 100k-ish around room temperature. If you don't get that value, check it again at the PCB on the HE280 where you soldered the thermistor leads to the PCB.
Fe_Lantern
When trying to test the connector with the multimeter probes, are the two metal contacts visible on the opposite side of the connector's clip sufficient for getting the reading? If so I am not getting a reading.
I then checked the soldered leads on the HE280 PCB and also had no reading.
This could be a sign of something that isn't right, or more likely my electronics/circuits ineptitude is showing.
If you're testing at the points where you soldered the thermistor into the HE280's circuit board and you're not getting a reading, either your meter is set wrong (should be the Ohm scale) or your thermistor needs to be replaced.
