How to fix, is this Stringing?
Doug68
Post by Doug68 »
I get this effect on parts with a concave side:
[img]https://lh3.googleusercontent.com/DDg7q ... no-tmp.jpg[/img]
This is with PLA running at 210c, as HE280, a 1mm retract at 25mm/s, z lift 1mm. Extrusion multiplier 1.
Any Ideas on how to reduce this?
Towards the middle of the part is where its starting the perimeter runs at that point there's a small bump on the top layer and the stringing follows out from this point also. From a practical point of view most of the time the concave side of the part is not important to me, but I'd like to get this cleaned up if I can.
thingismith
Re: How to fix, is this Stringing?
Post by thingismith »
Not getting the pic...do they look like branches or columns? Try upping your nonprint movement speed.
Doug68
Post by Doug68 »
I think I fixed the picture (Google photos) let me know if you cant see it still.
Here's the URL if no picture above: https://goo.gl/photos/YAaJymvZJnVT6XTs8
Cheers.
Post by Mac The Knife »
You fixed the picture,,, and yes, that's stringing.
Juicy
Post by Juicy »
https://www.simplify3d.com/support/prin ... ch-plastic
This is a guide I have used for tuning. It has to do with your retraction settings.
Doug68
Post by Doug68 »
To cut a long story short the retracts on my machine had become inafective due to slop in the bowden tube fittings, a cable tie as per the pic below fixed that.
Also after a few months of running nearly 24 - 7 I found nearly all the screws holding the machine together were lose.
And the spring apears to have gone soft on the extruder so that was slipping too easily.
[img]https://lh3.googleusercontent.com/76avh ... no-tmp.jpg[/img]
knabo
Post by knabo »
I will just add my situation to this thread, since it is relevant.
I finally got my V2 to V3 conversion printing decent walls and now it is on to retraction tuning.
References for this test are :
https://www.matterhackers.com/articles/ ... -to-oozing
https://www.simplify3d.com/support/prin ... eshooting/
http://www.sublimelayers.com/2016/10/so ... racts.html
And numerous posts on the subject
My current setting are:
Standard yellow PLA
190C hot end temp
300mm/s non-printing movement speed
and:
These are my results:
Where do I go from here?
Juicy
Post by Juicy »
From what I have read on this subject, and am going through as well; a lot of stringing is a result of a jam in the hotend. Are you sure your bowden tube is seated all the way? Heat the hotend up to 100C then pull the tube out and if you have a "hockey puck" of filament directly under the tube, you have found your problem. I believe that you should have no more than 2mm length on move for your retraction setting. Is your EZRstruder grinding filament?
knabo
Post by knabo »
The Bowden tube is seated and the tube locks are installed. I am using a bondtech extruder, it is not clicking or grinding.
My prints are pretty uniform, nothing that would indicate there is a jamming problem.
Stringing isn't a symptom of a jammed hot end. ;)
Stringing can happen when your printing temp is a bit high for the speed you're printing at. When I first work with a material in S3D, I set up similar basics to what you've got, but also add in a 4mm Z lift on retract. I then print a pair of 20mm cylinders to tune the temp to get it to stop stringing.
