Delta though...they stop me like a brick wall when it comes to diagnosing and figuring out.
I have a Rostock MAX V3 that has had calibrations since day 1 when I built it a couple months ago. SeeMe should be sending some replacement part for the bed any day now, in the meantime though, I have had pretty naughty ideas in my boredom and ended up raiding my spare parts drawer to see what mods I could do...
I have enough spare parts to build: (note none of these have been installed yet (except the Haydn rods [failure?])
* either a 1.75mm E3D-V6 or 3.00mm E3D-V6
* Titan extruder leftover from when I put a Bondtech on the C-BOT
* plenty of spare NEMA 17 2.0A 76oz (don't think these will be needed really)
* I have a set of trick trucks on the way from trick laser
* Maker713 effector
* Berd air max kit (newest one)
* Spare accelerometerr board from SeeMe
* Haydn 360mm mag arms
What I would like is some opinions on the following
1.75 or 3.0mm?
EZR or Titan Bowden (or possibly direct???)?
Firmware changes for the E3D (all my other machines run DUET so I am not sure what is needed on the RAMBO (aka noob))
Upgrade routes to approach here, Since I have the parts is it worth it? Curently, until new parts show up the printer is pretty much none functional unless I go back to original arms and print with a very nice, thick, ugly raft
Issues I have found so far (this is where I say that Deltas confuse me)
I installed the Haydn arms while I was bored during hurricane IRMA over the weekend. I tapped and installed the magballs directly into the barbell screw holes for the stock carriage and cheapskates. I updated the EEPROM for 360mm rod length and set the radius to about 155 for testing. Went to calibrate and the effector goes way off of the bed and smacks into the X tower hard enough to knock a few rods loose/off when trying to probe. For the life of me I cannot figure out why? I would really like to use this machine as my personal use machine for fun since all my other machines are pretty much dedicated to specific tasks/projects 24/7
Sorry if everything is jumbled up and out of whack. I have a habit of typing my thoughts as they go, so pardon me if I had any kind of wild tangents
