Hi all,
I have a SeeMeCNC Orion Delta that is still fairly new. The total print time amounts to 8 days worth, and the equipment is in good repair overall. Out of the blue, my printer no longer will heat up in order to print. I will set the target temp to over 210* C and it will not break past 190*C... and it takes a while to get there. I'm not sure what went wrong, but I am wondering if there's something awry with the thermostat / thermistor? And if that's true, how can I even identify that piece in an effort to troubleshoot / resolve the problem? I think that the issue should be minor, but I am learning about my machine so I'm not sure with where to start.
Thanks for your help!
Orion Nozzle is not heating beyond 190* C
Re: Orion Nozzle is not heating beyond 190* C
Using a digital multimeter, I would measure the resistance of the heater. I'm sure someone will chime in on what the resistance of two of the resistors in parallel should be.
- pouncingiguana
Which hot end do you have on your printer? Is it an HE280 with the accelerometer probe? Or the old peek hot end that you have to calibrate manually?
