I'd like to compile some tips and tricks to help builds go as smoothly as possible.
1 - Print one bearing block, and test that a 608zz fits snug in it before you print all of your bearing blocks.  If it doesn't, you may need a tighter tolerance on the block, or even a modified STL.  (We can provide if needed)
2 - Use m3 washers on any nuts that are facing a plastic component.  While not required, it's recommended.
3 - Check your linear rails, see if they're smooth. If they're not, loosen up the screws and adjust the end caps.  If that doesn't do it, you can remove all of the steel balls and soak them in denatured alcohol to clean them. Run a pipe cleaner soaked in alcohol through the blocks to clean them.  Lube them with PTFE oil and put them back in.  If  you're missing some, you can get replacements on Amazon cheap.
4 - Carefully label your extrusions when assembling the frame, so you don't flip any of the parts during assembly.  Some painters tape and a sharpie is an easy way to do this, and will avoid having to take it apart later to re-orient things.
Submit more tips you think of, and I'll add them to the list!
						Build Advice - to help your build go smoother
				Jump to
	- SeeMeCNC Announcments
 - ↳ General Announcments
 - ↳ SeeMeCNC crew in the wild
 - ↳ 3D Printing Contests
 - ↳ Development Topics
 - Software
 - ↳ Orca Slicer
 - ↳ SuperSlicer
 - ↳ Cura
 - ↳ Simplify3D
 - ↳ Slic3r
 - ↳ KISSlicer
 - ↳ Repetier Host
 - ↳ OctoPrint
 - ↳ Other
 - ↳ Sculptris
 - ↳ OpenSCAD
 - ↳ FreeCAD
 - ↳ Blender
 - ↳ SolidWorks
 - ↳ AutoDesk 123D
 - ↳ EMC2/LinuxCNC
 - ↳ Skeinforge
 - ↳ Mach3 Software
 - ↳ MatterControl
 - ↳ Creation Workshop
 - ↳ Fusion 360
 - General Forums
 - ↳ New Member introduction
 - ↳ The Lounge
 - ↳ Live Stream Announcments
 - ↳ Show us your machine!
 - ↳ What are YOU making?
 - ↳ General Tips 'N Tricks
 - ↳ Troubleshooting
 - ↳ Rostock MAX Official Docs
 - ↳ ORION Official Docs
 - ↳ GCode & Test Prints
 - ↳ The Build Zone
 - ↳ FAIL HAPPENS ! ! !
 - ↳ Filament
 - ↳ Test Forum
 - ↳ Members Marketplace
 - Extrusion Based Machines
 - ↳ Artemis
 - ↳ BOSSdelta 300
 - ↳ BOSSdelta 500
 - ↳ RostockMAX v4
 - ↳ RostockMAX v3.2
 - ↳ RostockMAX v3
 - ↳ ORION
 - ↳ ERIS Delta
 - ↳ Hacker Series - H2
 - ↳ Rostock MAX v2
 - ↳ Rostock MAX
 - ↳ H-1.1 3D Printers
 - ↳ H-1 3D Printers
 - ↳ Other Machines
 - ↳ RailCore
 - ↳ Scorpius™
 - ↳ Constellation
 - Regional Forums
 - ↳ Sprechen Sie Deutsch
 - ↳ Parlez-vous français
 - ↳ Hablas español
 - ↳ Australia and New Zealand
 - UV Liquid Resin Printers
 - ↳ DropLit
 - ↳ Resin Materials
 - ↳ Troubleshooting
 - ↳ Development Ideas
 - ↳ Skylight
 - Hardware Store
 - ↳ Nuts and Bolts
 - ↳ Computer Hardware
 - ↳ Mods and Upgrades
 - ↳ Heated Bed How-To's
 - Electronics
 - ↳ RAMBo
 - ↳ RAMPS
 - ↳ Azteeg X3 and X3 Pro
 - ↳ Beaglebone Black
 - ↳ Duet
 - ↳ Sanguino (lulu etc...)
 - ↳ Gen6 and variants
 - ↳ Printrboard
 - ↳ Power Supplies
 - ↳ Alligator Board
 - ↳ Other Controllers
 - ↳ OTHER Electronics
 - SeeMeEducate
 - ↳ Teachers Lounge
 - ↳ Show Your Work
 - ↳ Software Help
 - ↳ Design Help
 - ↳ Show and Tell
 - SeeMeFPV MultiRotor Forums
 - ↳ General FPV topics
 - ↳ Motors
 - ↳ ESC's
