Updating Firmware/ now current settings
kineprinter
Post by kineprinter »
Hi All,
I have a RMv2, Ball cup arm, HE280 (w/ HE300 head and thermister) and the accelerometer board. I am updating the firmware. it is now telling me i need motor currents to proceed with the upload. what do i need?
Re: Updating Firmware/ now current settings
That makes no sense. :) Can you post a screen shot of the error?
kineprinter
This is the error.
rootboy
Post by rootboy »
What it's telling you is that the variable/constant "MOTOR_CURRENT" is undefined in the scope of this routine. Where did you get your firmware files?
kineprinter
Github SeeMeCNC Firmware Master
rootboy
Post by rootboy »
Since you're being tight-lipped, I'm assuming version 0.92. Details Pinky, details...
You need to define "MOTOR_CURRENT" at some point
Look in either "configuration.h" for one of these lines, and uncomment one of them (remove the "#" from the front of the line):
#define MOTOR_CURRENT {140,140,140,130,0}
Did you run the configurator first?
MOTOR_CURRENT is already correctly defined. I suspect he's not set the configuration options for the printer and hot end type properly. (it's at the very top of Configuration.h)
ALL the firmware that the Rostock MAX v2 or 3 uses is 0.92. It's the revision date that's meaningful. :)
kineprinter
You were right geneb, I had put the machine type as Eris. Fixed that. Loaded the new firmware. Now my home direction is backwards. The firmware is 92.2 20171204. This is what I get for updating after running it for over 4000 hours and only minor upgrades. The hotend was causing issues and decided to do some upgrades.
kineprinter
I have set Zero from the LCD Panel (not in the same place it used to be), but my homing is still going down. if I move the axis, a positive movement goes down, negative goes up. And i noticed my extruder motor is not working. I will need to look at other posts about this.
Did you set your machine type to Rostock MAX v2?
kineprinter
Printer Model List as used throughout this firmware
Orion            = 1
Rostock Max V2   = 2
ERIS             = 3
Rostock MAX v3   = 5
Hacker H2        = 6
// ### Define your Printer Model here! ###
#define PRINTER 2
// SeeMeCNC Bowden w/PEEK barrel = 1
// HE240 on ERIS w/accel probe   = 2
// HE280 w/accel probe           = 3
#define HOTEND 3
// ### Define your motherboard here! ###
// 301 = RAMBo    302 = MINI RAMBo
#define MOTHERBOARD 301
// ##### Older Orions w/ATX had Y inverted and NEW PSU on orions needs opposite ###
// 1 = ATX on older machines  2 = Rail style PSU on newer machines ############################
#define POWER_SUPPLY 1
// ### Number of active extruders
// 1 is standard, 2 is with the Y coupler for dual filament input
// WARNING: There is a known bug in Repetier that causes random tool changes when using dual
// extrusion if you have the USB cable connected. In order to avoid this, only print from
// the SD card if you are running two extruders.
#define NUM_EXTRUDER 1
// ################# BASIC CONFIGURATION IS ALL DONE ABOVE HERE ###############################
// ########### ONLY ADVANCCED USERS SHOULD MODIFY ANYTHING BELOW THIS LINE ####################
// ############ FW version info and build date for LCD and M115 string! #######################
#define REPETIER_VERSION "0.92.2"
#define FIRMWARE_DATE "20171204" // in date format yyyymmdd
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
#define ADVANCED_USER 1 // Change to 1 to unlock full menus
#include "pins.h"
//  Microstepping mode of your stepper drivers
#define MICROSTEP_MODES {16,16,16,16,16} // 1,2,4,8,16
#if MOTHERBOARD == 301  // RAMBo
#define STEPPER_CURRENT_CONTROL CURRENT_CONTROL_DIGIPOT
#elif MOTHERBOARD == 302  // Mini RAMBo
#define STEPPER_CURRENT_CONTROL CURRENT_CONTROL_PWM
#define MOTOR_CURRENT_PWM_RANGE 2000
#endif
#define Z_LIFT_ON_PAUSE 20         // Amount to lift the head (mm) when pausing from the LCD screen
#define MIN_DEFECT_TEMPERATURE 16  // this is the min temp that will allow the hotend to start heating.  Below this it will show as defective to help identify bad thermistors
#define MAX_DEFECT_TEMPERATURE 300 // this is the max temp that wthe printer will throw errors about defective thermistors
#define MIXING_EXTRUDER 0
#define DRIVE_SYSTEM 3
#define BELT_PITCH 2
#define PULLEY_TEETH 20
#define PULLEY_CIRCUMFERENCE (BELT_PITCH * PULLEY_TEETH)
#define PULLEY_DIAMETER 10
//#define PULLEY_CIRCUMFERENCE (PULLEY_DIAMETER * 3.1415927)
#define STEPS_PER_ROTATION 200
#define MICRO_STEPS 16
#define AXIS_STEPS_PER_MM ((float)(MICRO_STEPS * STEPS_PER_ROTATION) / PULLEY_CIRCUMFERENCE)  // for deltas with 1.8 deg. steppers and 20 tooth GT2 pulleys
#define XAXIS_STEPS_PER_MM AXIS_STEPS_PER_MM
#define YAXIS_STEPS_PER_MM AXIS_STEPS_PER_MM
#define ZAXIS_STEPS_PER_MM AXIS_STEPS_PER_MM
// ### Hotend and Extruder configuration
#define MIN_EXTRUDER_TEMP 150
#if HOTEND == 1
#define MAXTEMP 240
#define UI_SET_MAX_EXTRUDER_TEMP 240
#define EXT0_PID_INTEGRAL_DRIVE_MAX 180
#define EXT0_PID_INTEGRAL_DRIVE_MIN 80
#define EXT0_PID_PGAIN_OR_DEAD_TIME 14.50
#define EXT0_PID_I 0.73
#define EXT0_PID_D 53.41
#define EXT0_PID_MAX 235
#define EXT1_PID_INTEGRAL_DRIVE_MAX 180
#define EXT1_PID_INTEGRAL_DRIVE_MIN 80
#define EXT1_PID_PGAIN_OR_DEAD_TIME 14.50
#define EXT1_PID_I 0.73
#define EXT1_PID_D 53.41
#define EXT1_PID_MAX 235
#elif HOTEND == 2
#define MAXTEMP 240
#define EXT0_PID_INTEGRAL_DRIVE_MAX 200
#define EXT0_PID_INTEGRAL_DRIVE_MIN 120
#define EXT0_PID_PGAIN_OR_DEAD_TIME 25.0
#define EXT0_PID_I 0.85
#define EXT0_PID_D 176.0
#define EXT0_PID_MAX 210
#elif HOTEND == 3
#define MAXTEMP 290
#define UI_SET_MAX_EXTRUDER_TEMP 280
#define EXT0_PID_INTEGRAL_DRIVE_MAX 230
#define EXT0_PID_PGAIN_OR_DEAD_TIME 48.3
#define EXT0_PID_I 9.7
#define EXT0_PID_D 60.0
#define EXT0_PID_MAX 255
#define EXT1_PID_INTEGRAL_DRIVE_MAX 230
#define EXT1_PID_PGAIN_OR_DEAD_TIME 48.3
#define EXT1_PID_I 9.7
#define EXT1_PID_D 60.0
#define EXT1_PID_MAX 255
#endif
// using PWM not PDM
#define PDM_FOR_EXTRUDER 0
#define PDM_FOR_COOLER 0
#define FEATURE_WATCHDOG 1
#define DECOUPLING_TEST_MAX_HOLD_VARIANCE 20
#define DECOUPLING_TEST_MIN_TEMP_RISE 1
#define RETRACT_ON_PAUSE 2
#define PAUSE_START_COMMANDS "G91/nG1 Z10.0 E-5.0 F1500/nG90/n"
#define PAUSE_END_COMMANDS "G91/nG1 Z-10.0 E5.1 F1500/nG90/n"
// ### EXT0 Setup ###
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET 0
#define EXT0_STEPS_PER_MM 92.4
#define EXT0_TEMPSENSOR_TYPE 97 //97
#define EXT0_TEMPSENSOR_PIN TEMP_0_PIN
#define EXT0_HEATER_PIN HEATER_0_PIN
#define EXT0_STEP_PIN ORIG_E0_STEP_PIN
#define EXT0_DIR_PIN ORIG_E0_DIR_PIN
#define EXT0_INVERSE 1
#define EXT0_ENABLE_PIN E0_ENABLE_PIN
#define EXT0_ENABLE_ON 0
#define EXT0_MAX_FEEDRATE 100
#define EXT0_MAX_START_FEEDRATE 45
#define EXT0_MAX_ACCELERATION 6500
#define EXT0_HEAT_MANAGER 1
#define EXT0_WATCHPERIOD 3
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_ADVANCE_BACKLASH_STEPS 0
#define EXT0_WAIT_RETRACT_TEMP 150
#define EXT0_WAIT_RETRACT_UNITS 0
#define EXT0_SELECT_COMMANDS "M117 Extruder 0\nT0\nM84 P4\nG91\nG1E172F6000\nG1E5F500\nG90"
#define EXT0_DESELECT_COMMANDS "G91\nG1E-180F6000\nG90"
#define EXT0_EXTRUDER_COOLER_PIN 7
#define EXT0_EXTRUDER_COOLER_PIN -1
#endif
#define EXTRUDER_FAN_COOL_TEMP 40
#define EXT0_EXTRUDER_COOLER_SPEED 200
#define EXT0_DECOUPLE_TEST_PERIOD 45000
// ### EXT1 Setup ###
#define EXT1_X_OFFSET 0
#define EXT1_Y_OFFSET 0
#define EXT1_STEPS_PER_MM 92.4
#define EXT1_TEMPSENSOR_TYPE 97 //97
#define EXT1_TEMPSENSOR_PIN TEMP_1_PIN
#define EXT1_HEATER_PIN HEATER_1_PIN
#define EXT1_STEP_PIN ORIG_E1_STEP_PIN
#define EXT1_DIR_PIN ORIG_E1_DIR_PIN
#define EXT1_INVERSE 1
#define EXT1_ENABLE_PIN E1_ENABLE_PIN
#define EXT1_ENABLE_ON 0
#define EXT1_MAX_FEEDRATE 100
#define EXT1_MAX_START_FEEDRATE 45
#define EXT1_MAX_ACCELERATION 6500
#define EXT1_HEAT_MANAGER 1
#define EXT1_WATCHPERIOD 3
#define EXT1_ADVANCE_K 0
#define EXT1_ADVANCE_L 0
#define EXT1_ADVANCE_BACKLASH_STEPS 0
#define EXT1_WAIT_RETRACT_TEMP 150
#define EXT1_WAIT_RETRACT_UNITS 0
#define EXT1_SELECT_COMMANDS "M117 Extruder 1\nT1\nM84 P4\nG91\nG1E172F6000\nG1E5F500\nG90"
#define EXT1_DESELECT_COMMANDS "G91\nG1E-180F6000\nG90"
#define EXT1_EXTRUDER_COOLER_PIN 7
#define EXT1_EXTRUDER_COOLER_PIN -1
#endif
#define EXT1_EXTRUDER_COOLER_SPEED 200
#define EXT1_DECOUPLE_TEST_PERIOD 45000
// ############# Heated bed configuration ########################
#define HEATED_BED_MAX_TEMP 120
#define SKIP_M190_IF_WITHIN 5
#define HEATED_BED_SENSOR_TYPE 97 //97
#define HEATED_BED_SENSOR_PIN TEMP_BED_PIN
#define HEATED_BED_HEATER_PIN HEATER_BED_PIN
#define HEATED_BED_SET_INTERVAL 5000
#define HEATED_BED_HEAT_MANAGER 1
#define HEATED_BED_PID_INTEGRAL_DRIVE_MAX 255
#define HEATED_BED_PID_INTEGRAL_DRIVE_MIN 80
#define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   87.86
#define HEATED_BED_PID_IGAIN   3.01
#define HEATED_BED_PID_DGAIN 641.82
#define HEATED_BED_PID_MAX 255
#define HEATED_BED_DECOUPLE_TEST_PERIOD 300000
// ### PRINTER SPECIFIC SETTINGS ###
#if PRINTER == 1  // Orion Delta
#if NUM_EXTRUDER == 1
#elif NUM_EXTRUDER == 2
#define MOTOR_CURRENT {140,140,140,145,145}
#endif
#define MOTOR_CURRENT_PWM {60, 60, 130}
#endif
#define HAVE_HEATED_BED 1
#define INVERT_X_DIR 1
#if POWER_SUPPLY == 2
#define INVERT_Y_DIR 1
#else
#define INVERT_Y_DIR 0
#endif
#define INVERT_Z_DIR 1
#define DELTA_DIAGONAL_ROD 178.0  // ball cup arms
#define DELTA_MAX_RADIUS 90.0
#define PRINTER_RADIUS 145.7
#define Z_MAX_LENGTH 230.0
#define END_EFFECTOR_HORIZONTAL_OFFSET 30.22
#define CARRIAGE_HORIZONTAL_OFFSET 26.5  // molded cheapskates
#define DELTASEGMENTS_PER_PRINTLINE 22
#define STEPPER_INACTIVE_TIME 600L
#define MAX_INACTIVE_TIME 900L
#define MAX_FEEDRATE_X 250
#define MAX_FEEDRATE_Y 250
#define MAX_FEEDRATE_Z 250
#define HOMING_FEEDRATE_X 80
#define HOMING_FEEDRATE_Y 80
#define HOMING_FEEDRATE_Z 80
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 1650
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 1650
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 1650
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 2800
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 2800
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 2800
#define MAX_JERK 28
#define MAX_ZJERK 28
#if HOTEND == 3
#define FEATURE_Z_PROBE 1
#else
#define FEATURE_Z_PROBE 0
#endif
#define Z_PROBE_SENSITIVITY  20 // 0-126 7 bit value
#define Z_PROBE_BED_DISTANCE 20
#define Z_PROBE_PULLUP 1 //0
#define Z_PROBE_ON_HIGH 0 //1
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_WAIT_BEFORE_TEST 0
#define Z_PROBE_SPEED 60
#define Z_PROBE_XY_SPEED 50
#define Z_PROBE_SWITCHING_DISTANCE 10
#define Z_PROBE_REPETITIONS 1
#define Z_PROBE_HEIGHT -0.1
#define Z_PROBE_START_SCRIPT "G28/nG1Z25/n"
//#define Z_PROBE_START_SCRIPT "M117 Probe Started/n"
#define Z_PROBE_FINISHED_SCRIPT ""
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 -75.933
#define Z_PROBE_Y1 -43.84
#define Z_PROBE_X2 75.933
#define Z_PROBE_Y2 -43.84
#define Z_PROBE_X3 0
#define Z_PROBE_Y3 87.69
#define SDSUPPORT 1
#define SDCARDDETECT 81
#define SDCARDDETECTINVERTED 0
#define FEATURE_CONTROLLER 13
#define UI_PRINTER_NAME "ORION Delta"
#define SDSUPPORT 1
#elif PRINTER == 2 // Rostock MAX v2
#define MOTOR_CURRENT {140,140,140,130,130}
#endif
#define DELTA_DIAGONAL_ROD 291.06  // ball cup arms
#define DELTA_MAX_RADIUS 145.0
#define PRINTER_RADIUS 200.0
#define Z_MAX_LENGTH 350
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 1850
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 1850
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 1850
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 3000
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 3000
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 3000
#define MAX_JERK 32
#define MAX_ZJERK 32
#if HOTEND == 3
#else
#endif
#define Z_PROBE_X1 -123.565
#define Z_PROBE_Y1 -71.34
#define Z_PROBE_X2 123.565
#define Z_PROBE_Y2 -71.340
#define Z_PROBE_Y3 142.68
#define SDSUPPORT 1
#define UI_PRINTER_NAME "RostockMAXv2"
#elif PRINTER == 3  // ERIS Delta
#define MOTOR_CURRENT_PWM {20, 20, 130}
#define INVERT_X_DIR 0
#define INVERT_Z_DIR 0
#define DELTA_DIAGONAL_ROD 134.9  // 134.58 early measurement
#define DELTA_MAX_RADIUS 65  // max printable area allowed by firmware
#define PRINTER_RADIUS 98.38  //PRINTER_RADIUS-END_EFFECTOR_HORIZONTAL_OFFSET-CARRIAGE_HORIZONTAL_OFFSET
#define Z_MAX_LENGTH 175.0
#define END_EFFECTOR_HORIZONTAL_OFFSET 23.38
#define CARRIAGE_HORIZONTAL_OFFSET 10
#define MAX_FEEDRATE_X 125
#define MAX_FEEDRATE_Y 125
#define MAX_FEEDRATE_Z 125
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 250
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 250
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 250
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 400
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 400
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 400
#define MAX_JERK 12
#define MAX_ZJERK 12
#define Z_PROBE_SENSITIVITY  25 // 0-126 7 bit value
#define Z_PROBE_SPEED 90
#define Z_PROBE_HEIGHT -0.2
#define Z_PROBE_X1 -54
#define Z_PROBE_Y1 -31
#define Z_PROBE_X2  54
#define Z_PROBE_Y2 -31
#define Z_PROBE_Y3  65
#define UI_PRINTER_NAME "ERIS Delta"
#define FEATURE_CONTROLLER 0
#define HAVE_HEATED_BED 0
#define FAN_BOARD_PIN 6  //Cooling fan on RAMBo board
#elif PRINTER == 5  // Rostock MAX v3
#endif
#define Z_MAX_LENGTH 395
#define MAX_JERK 32
#define Z_PROBE_SPEED 80
#define SDSUPPORT 1
#define UI_PRINTER_NAME "RostockMAXv3"
#elif PRINTER == 6  // Hacker H2
#endif
#define MOTOR_CURRENT_PWM {100, 100, 130}
#endif
#define DELTA_MAX_RADIUS 72.0
#define PRINTER_RADIUS 155.0
#define Z_MAX_LENGTH 295.0
#define MAX_JERK 32
#define SDSUPPORT 1
#define UI_PRINTER_NAME "Hacker H2"
#endif
#define FEATURE_RETRACTION 0
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 3
#define RETRACTION_LONG_LENGTH 13
#define RETRACTION_SPEED 40
#define RETRACTION_Z_LIFT 0
#define RETRACTION_UNDO_EXTRA_LENGTH 0
#define RETRACTION_UNDO_EXTRA_LONG_LENGTH 0
#define RETRACTION_UNDO_SPEED 20
#define FILAMENTCHANGE_X_POS 0
#define FILAMENTCHANGE_Y_POS 0
#define FILAMENTCHANGE_Z_ADD  2
#define FILAMENTCHANGE_REHOME 1
#define FILAMENTCHANGE_SHORTRETRACT 5
#define FILAMENTCHANGE_LONGRETRACT 50
#define RETRACT_DURING_HEATUP true
#define PID_CONTROL_RANGE 20
#define SKIP_M109_IF_WITHIN 5
#define SCALE_PID_TO_MAX 0
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 1000
#define NUM_TEMPS_USERTHERMISTOR0 0
#define USER_THERMISTORTABLE0 {}
#define NUM_TEMPS_USERTHERMISTOR1 0
#define USER_THERMISTORTABLE1 {}
#define NUM_TEMPS_USERTHERMISTOR2 0
#define USER_THERMISTORTABLE2 {}
#define USE_GENERIC_THERMISTORTABLE_1
#define GENERIC_THERM1_T0 25
#define GENERIC_THERM1_R0 100000
#define GENERIC_THERM1_BETA 4450 //4267
#define GENERIC_THERM1_MIN_TEMP -50
#define GENERIC_THERM1_MAX_TEMP 300
#define GENERIC_THERM1_R1 0
#define GENERIC_THERM1_R2 4700
#define USE_GENERIC_THERMISTORTABLE_2
#define GENERIC_THERM2_T0 25
#define GENERIC_THERM2_R0 100000
#define GENERIC_THERM2_BETA 4367
#define GENERIC_THERM2_MIN_TEMP -20
#define GENERIC_THERM2_MAX_TEMP 300
#define GENERIC_THERM2_R1 0
#define GENERIC_THERM2_R2 4700
#define GENERIC_THERM_VREF 5
#define GENERIC_THERM_NUM_ENTRIES 33
#define HEATER_PWM_SPEED 0
// ################ Endstop configuration #####################
#define ENDSTOP_PULLUP_X_MIN true
#define ENDSTOP_X_MIN_INVERTING false
#define MIN_HARDWARE_ENDSTOP_X false
#define ENDSTOP_PULLUP_Y_MIN true
#define ENDSTOP_Y_MIN_INVERTING false
#define MIN_HARDWARE_ENDSTOP_Y false
#define ENDSTOP_PULLUP_Z_MIN true
#define ENDSTOP_Z_MIN_INVERTING true
#define MIN_HARDWARE_ENDSTOP_Z false
#define ENDSTOP_PULLUP_X_MAX true
#define ENDSTOP_X_MAX_INVERTING false
#define MAX_HARDWARE_ENDSTOP_X true
#define ENDSTOP_PULLUP_Y_MAX true
#define ENDSTOP_Y_MAX_INVERTING false
#define MAX_HARDWARE_ENDSTOP_Y true
#define ENDSTOP_PULLUP_Z_MAX true
#define ENDSTOP_Z_MAX_INVERTING false
#define MAX_HARDWARE_ENDSTOP_Z true
#define max_software_endstop_r true
#define min_software_endstop_x false
#define min_software_endstop_y false
#define min_software_endstop_z false
#define max_software_endstop_x true
#define max_software_endstop_y true
#define max_software_endstop_z true
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 5
#define ENDSTOP_X_RETEST_REDUCTION_FACTOR 2
#define ENDSTOP_Y_RETEST_REDUCTION_FACTOR 2
#define ENDSTOP_Z_RETEST_REDUCTION_FACTOR 2
#define ENDSTOP_X_BACK_ON_HOME 5
#define ENDSTOP_Y_BACK_ON_HOME 5
#define ENDSTOP_Z_BACK_ON_HOME 5
#define ALWAYS_CHECK_ENDSTOPS 1
// ################# XYZ movements ###################
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
// ######   Inverting Axis Settings for Orion/Rostock MAX v2/DropLit
#define X_HOME_DIR 1
#define Y_HOME_DIR 1
#define Z_HOME_DIR 1
#define X_MAX_LENGTH 250
#define Y_MAX_LENGTH 250
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
// ###   Distortion correction for bed mapping ###
#define DISTORTION_CORRECTION 0
#define DISTORTION_CORRECTION_POINTS 5
#define DISTORTION_CORRECTION_R 100
#define DISTORTION_PERMANENT 1
#define DISTORTION_UPDATE_FREQUENCY 15
#define DISTORTION_START_DEGRADE 0.5
#define DISTORTION_END_HEIGHT 1
#define DISTORTION_EXTRAPOLATE_CORNERS 0
// ##                           Movement settings                                          ##
#define FEATURE_BABYSTEPPING 1
#define BABYSTEP_MULTIPLICATOR 1
#define DELTA_SEGMENTS_PER_SECOND_PRINT 200 // Move accurate setting for print moves
#define DELTA_SEGMENTS_PER_SECOND_MOVE 80 // Less accurate setting for other moves
#define DELTA_ALPHA_A 210
#define DELTA_ALPHA_B 330
#define DELTA_ALPHA_C 90
#define DELTA_RADIUS_CORRECTION_A 0
#define DELTA_RADIUS_CORRECTION_B 0
#define DELTA_RADIUS_CORRECTION_C 0
#define DELTA_DIAGONAL_CORRECTION_A 0
#define DELTA_DIAGONAL_CORRECTION_B 0
#define DELTA_DIAGONAL_CORRECTION_C 0
#define DELTA_HOME_ON_POWER 0
#define STEP_COUNTER
#define DELTA_X_ENDSTOP_OFFSET_STEPS 0
#define DELTA_Y_ENDSTOP_OFFSET_STEPS 0
#define DELTA_Z_ENDSTOP_OFFSET_STEPS 0
#define DELTA_FLOOR_SAFETY_MARGIN_MM 15
#define HOMING_ORDER HOME_ORDER_ZXY
#define ENABLE_BACKLASH_COMPENSATION 0
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 0
#define DIRECTION_DELAY 0
#define STEP_DOUBLER_FREQUENCY 12000
#define ALLOW_QUADSTEPPING 1
#define DOUBLE_STEP_DELAY 1 // time in microseconds
#define MAX_HALFSTEP_INTERVAL 1999
#define PRINTLINE_CACHE_SIZE 16
#define MOVE_CACHE_LOW 10
#define LOW_TICKS_PER_MOVE 250000
#define FEATURE_TWO_XSTEPPER 0
#define X2_STEP_PIN   ORIG_E1_STEP_PIN
#define X2_DIR_PIN    ORIG_E1_DIR_PIN
#define X2_ENABLE_PIN ORIG_E1_ENABLE_PIN
#define FEATURE_TWO_YSTEPPER 0
#define Y2_STEP_PIN   ORIG_E1_STEP_PIN
#define Y2_DIR_PIN    ORIG_E1_DIR_PIN
#define Y2_ENABLE_PIN ORIG_E1_ENABLE_PIN
#define FEATURE_TWO_ZSTEPPER 0
#define Z2_STEP_PIN   ORIG_E1_STEP_PIN
#define Z2_DIR_PIN    ORIG_E1_DIR_PIN
#define Z2_ENABLE_PIN ORIG_E1_ENABLE_PIN
#define FEATURE_DITTO_PRINTING 0
#define USE_ADVANCE 1
#define ENABLE_QUADRATIC_ADVANCE 0
// ################# Misc. settings ##################
#define BAUDRATE 250000
#define ENABLE_POWER_ON_STARTUP 1
#define POWER_INVERTING 0
#define KILL_METHOD 1
#define GCODE_BUFFER_SIZE 2
#define ACK_WITH_LINENUMBER 0
#define WAITING_IDENTIFIER "wait"
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 1
/* ======== Servos =======
Control the servos with
M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
Servos are controlled by a pulse width normally between 500 and 2500 with 1500ms in center position. 0 turns servo off.
WARNING: Servos can draw a considerable amount of current. Make sure your system can handle this or you may risk your hardware!
#define FEATURE_SERVO 0
#define SERVO0_PIN -1
#define SERVO1_PIN -1
#define SERVO2_PIN -1
#define SERVO3_PIN -1
/* #################### Z-Probe configuration and Settings #####################
   These will change machine to machine, be sure to have the correct machine selected in the top of this config file
// 301 = RAMBO    302 = MINI_RAMBO
#define Z_PROBE_PIN 4
#define Z_PROBE_PIN 16
#endif
#define Z_PROBE_TOLERANCE .1
#define Z_PROBE_MAX_SENSITIVITY 40
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
// ##############  SD Card Settings  #########################
#define SD_EXTENDED_DIR 1 /** Show extended directory including file length. Don't use this with Pronterface! */
#define SD_RUN_ON_STOP ""
#define SD_STOP_HEATER_AND_MOTORS_ON_STOP 1
#define ARC_SUPPORT 0
#define FEATURE_MEMORY_POSITION 1
#define FEATURE_CHECKSUM_FORCED 0
#define FEATURE_FAN_CONTROL 1
#define UI_LANGUAGE 1000 // 1000 = User defined language in v92+
#define UI_PRINTER_COMPANY "SeeMeCNC"
#define UI_ENCODER_DIR 1 // 0 normal 1 inverts encoder direction
#define UI_PAGES_DURATION 4000
#define UI_ANIMATION 0
#define UI_SPEEDDEPENDENT_POSITIONING 1
#define UI_DISABLE_AUTO_PAGESWITCH 1
#define UI_AUTORETURN_TO_MENU_AFTER 600000
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 2
#define UI_KEY_BOUNCETIME 10
#define UI_KEY_FIRST_REPEAT 500
#define UI_KEY_REDUCE_REPEAT 50
#define UI_KEY_MIN_REPEAT 50
#define FEATURE_BEEPER 1
#define CASE_LIGHTS_PIN -1
#define CASE_LIGHT_DEFAULT_ON 1
#define UI_START_SCREEN_DELAY 1000
Beeper sound definitions for short beeps during key actions
and longer beeps for important actions.
Parameter is delay in microseconds and the secons is the number of repetitions.
Values must be in range 1..255
#define BEEPER_SHORT_SEQUENCE 1,1
#define BEEPER_LONG_SEQUENCE 32,4
#define UI_SET_PRESET_HEATED_BED_TEMP_PLA 60
#define UI_SET_PRESET_EXTRUDER_TEMP_PLA   180
#define UI_SET_PRESET_HEATED_BED_TEMP_ABS 80
#define UI_SET_PRESET_EXTRUDER_TEMP_ABS   200
#define UI_SET_MIN_HEATED_BED_TEMP  30
#define UI_SET_MAX_HEATED_BED_TEMP 120
#define UI_SET_MIN_EXTRUDER_TEMP   150
#define UI_SET_EXTRUDER_FEEDRATE 2
#define UI_SET_EXTRUDER_RETRACT_DISTANCE 3
#endif
rootboy
Post by rootboy »
geneb wrote:MOTOR_CURRENT is already correctly defined. I suspect he's not set the configuration options for the printer and hot end type properly. (it's at the very top of Configuration.h)
That's right. Pesky C programmers...
rootboy
Post by rootboy »
Try making one of your Endstop limits while it is trying to home in the wrong direction. I had problems with the drive going in the wrong direction, swapping motor direction fixed it.
I looked over your Config.h and compared it to one of my old ones. This struck me as odd:
Do you really have that type of thermistor?
kineprinter
geneb,
Adding the Z length did nothing. I changed the motor direction on all 3 motors, and that worked. I found out I had to change the motor direction on the extruder too. It is up and running, and does a G29 calibration now too. Thanks for all your help.
rootboy
Post by rootboy »
Very cool!
Did you look at your thermistor type? 97 is the default type in an unmodified Configuration.h file. I think that Rostocks come with type 8 normally (Gene would know).
I'm pretty sure the default thermistor in Configuration.h is correct.
