Downloaded Arduino 1.8.6
Ran eeprom_clear (That worked great, now I have no firmware)
Every time I try to compile I get this
Arduino: 1.8.6 (Windows 10), Board: "RAMBo"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\USER\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\USER\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\USER\Documents\Arduino\libraries -fqbn=rambo:avr:rambo -vid-pid=0X27B1_0X0001 -ide-version=10806 -build-path C:\Users\USER\AppData\Local\Temp\arduino_build_199297 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\USER\Downloads\Firmware-master (12-04-2017)\Firmware-master\Repetier Firmware\Repetier\Repetier.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\USER\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\USER\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\USER\Documents\Arduino\libraries -fqbn=rambo:avr:rambo -vid-pid=0X27B1_0X0001 -ide-version=10806 -build-path C:\Users\USER\AppData\Local\Temp\arduino_build_199297 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\USER\Downloads\Firmware-master (12-04-2017)\Firmware-master\Repetier Firmware\Repetier\Repetier.ino
Using board 'rambo' from platform in folder: C:\Users\USER\AppData\Local\Arduino15\packages\rambo\hardware\avr\1.0.1
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Repetier.ino.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Repetier.ino.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Repetier.ino.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Commands.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Communication.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Eeprom.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Extruder.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\HAL.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Printer.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\SDCard.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\SdFat.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\gcode.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\motion.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\ui.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src\\SPI.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src\\Wire.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src\\utility\\twi.c" -o nul
Generating function prototypes...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Repetier.ino.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Communication.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Communication.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Commands.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Commands.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Extruder.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Extruder.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\SDCard.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\SDCard.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Eeprom.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Eeprom.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\SdFat.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\SdFat.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\motion.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\motion.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\ui.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\ui.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Repetier.ino.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Repetier.ino.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\gcode.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\gcode.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\HAL.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\HAL.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Printer.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Printer.cpp.o"
Compiling libraries...
Compiling library "SPI"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src\\SPI.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\libraries\\SPI\\SPI.cpp.o"
Compiling library "Wire"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src\\Wire.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\libraries\\Wire\\Wire.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src\\utility\\twi.c" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\libraries\\Wire\\utility\\twi.c.o"
Compiling core...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -c -g -x assembler-with-cpp -flto -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\wiring_pulse.S" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\wiring_pulse.S.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\wiring_digital.c" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\wiring_digital.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\wiring_analog.c" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\wiring_analog.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\hooks.c" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\hooks.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\wiring_pulse.c" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\wiring_pulse.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\WInterrupts.c" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\WInterrupts.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\wiring_shift.c" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\wiring_shift.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\wiring.c" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\wiring.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\main.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\main.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\HardwareSerial0.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\HardwareSerial0.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\Print.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\Print.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\HardwareSerial.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\HardwareSerial.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\HardwareSerial1.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\HardwareSerial1.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\Stream.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\Stream.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\CDC.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\CDC.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\HardwareSerial2.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\HardwareSerial2.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\USBCore.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\USBCore.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\new.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\new.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\Tone.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\Tone.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\HardwareSerial3.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\HardwareSerial3.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\WMath.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\WMath.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\IPAddress.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\IPAddress.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\PluggableUSB.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\PluggableUSB.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\WString.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\WString.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\rambo\\hardware\\avr\\1.0.1\\variants\\rambo" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino\\abi.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\abi.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\CDC.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\HardwareSerial.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\HardwareSerial0.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\HardwareSerial1.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\HardwareSerial2.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\HardwareSerial3.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\IPAddress.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\PluggableUSB.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\Print.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\Stream.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\Tone.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\USBCore.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\WInterrupts.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\WMath.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\WString.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\abi.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\hooks.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\main.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\new.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\wiring.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\wiring_analog.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\wiring_digital.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\wiring_pulse.S.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\wiring_pulse.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc-ar" rcs "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\core.a" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\core\\wiring_shift.c.o"
Linking everything together...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections,--relax -mmcu=atmega2560 -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297/Repetier.ino.elf" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Commands.cpp.o" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Communication.cpp.o" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Eeprom.cpp.o" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Extruder.cpp.o" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\HAL.cpp.o" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Printer.cpp.o" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\Repetier.ino.cpp.o" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\SDCard.cpp.o" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\SdFat.cpp.o" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\gcode.cpp.o" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\motion.cpp.o" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\sketch\\ui.cpp.o" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\libraries\\SPI\\SPI.cpp.o" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\libraries\\Wire\\Wire.cpp.o" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297\\libraries\\Wire\\utility\\twi.c.o" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297/core\\core.a" "-LC:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_199297" -lm
C:\Users\USER\AppData\Local\Temp\ccu2dGhq.ltrans6.ltrans.o: In function `__vector_17':
C:\Users\USER\AppData\Local\Temp\arduino_build_199297\sketch/HAL.cpp:677: undefined reference to `stepperWait'
C:\Users\USER\AppData\Local\Temp\ccu2dGhq.ltrans6.ltrans.o:C:\Users\USER\AppData\Local\Temp\arduino_build_199297\sketch/HAL.cpp:677: more undefined references to `stepperWait' follow
collect2.exe: error: ld returned 1 exit status
Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
Using library Wire at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire
exit status 1
Error compiling for board RAMBo.Code: Select all
Arduino: 1.8.5 (Windows 10), Board: "RAMBo"
C:\arduino-1.8.5\arduino-builder -dump-prefs -logger=machine -hardware C:\arduino-1.8.5\hardware -hardware C:\Users\USER\AppData\Local\Arduino15\packages -tools C:\arduino-1.8.5\tools-builder -tools C:\arduino-1.8.5\hardware\tools\avr -tools C:\Users\USER\AppData\Local\Arduino15\packages -built-in-libraries C:\arduino-1.8.5\libraries -libraries C:\Users\USER\Documents\Arduino\libraries -fqbn=rambo:avr:rambo -vid-pid=0X27B1_0X0001 -ide-version=10805 -build-path C:\Users\USER\AppData\Local\Temp\arduino_build_446917 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\arduino-1.8.5\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\arduino-1.8.5\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\arduino-1.8.5\hardware\tools\avr -verbose C:\Users\USER\Downloads\Firmware-master (12-04-2017)\Firmware-master\Repetier Firmware\Repetier\Repetier.ino
C:\arduino-1.8.5\arduino-builder -compile -logger=machine -hardware C:\arduino-1.8.5\hardware -hardware C:\Users\USER\AppData\Local\Arduino15\packages -tools C:\arduino-1.8.5\tools-builder -tools C:\arduino-1.8.5\hardware\tools\avr -tools C:\Users\USER\AppData\Local\Arduino15\packages -built-in-libraries C:\arduino-1.8.5\libraries -libraries C:\Users\USER\Documents\Arduino\libraries -fqbn=rambo:avr:rambo -vid-pid=0X27B1_0X0001 -ide-version=10805 -build-path C:\Users\USER\AppData\Local\Temp\arduino_build_446917 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\arduino-1.8.5\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\arduino-1.8.5\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\arduino-1.8.5\hardware\tools\avr -verbose C:\Users\USER\Downloads\Firmware-master (12-04-2017)\Firmware-master\Repetier Firmware\Repetier\Repetier.ino
Using core 'arduino' from platform in folder: C:\arduino-1.8.5\hardware\arduino\avr
"C:\arduino-1.8.5\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.8.5\hardware\arduino\avr\cores\arduino" "-IC:\Users\USER\AppData\Local\Arduino15\packages\rambo\hardware\avr\1.0.1\variants\rambo" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Repetier.ino.cpp" -o "nul"
"C:\arduino-1.8.5\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.8.5\hardware\arduino\avr\cores\arduino" "-IC:\Users\USER\AppData\Local\Arduino15\packages\rambo\hardware\avr\1.0.1\variants\rambo" "-IC:\arduino-1.8.5\hardware\arduino\avr\libraries\SPI\src" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Repetier.ino.cpp" -o "nul"
"C:\arduino-1.8.5\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.8.5\hardware\arduino\avr\cores\arduino" "-IC:\Users\USER\AppData\Local\Arduino15\packages\rambo\hardware\avr\1.0.1\variants\rambo" "-IC:\arduino-1.8.5\hardware\arduino\avr\libraries\SPI\src" "-IC:\arduino-1.8.5\hardware\arduino\avr\libraries\Wire\src" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Repetier.ino.cpp" -o "nul"
Using cached library dependencies for file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Commands.cpp
Using cached library dependencies for file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Communication.cpp
Using cached library dependencies for file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Eeprom.cpp
Using cached library dependencies for file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Extruder.cpp
Using cached library dependencies for file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\HAL.cpp
Using cached library dependencies for file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Printer.cpp
Using cached library dependencies for file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\SDCard.cpp
Using cached library dependencies for file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\SdFat.cpp
Using cached library dependencies for file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\gcode.cpp
Using cached library dependencies for file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\motion.cpp
Using cached library dependencies for file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\ui.cpp
Using cached library dependencies for file: C:\arduino-1.8.5\hardware\arduino\avr\libraries\SPI\src\SPI.cpp
Using cached library dependencies for file: C:\arduino-1.8.5\hardware\arduino\avr\libraries\Wire\src\Wire.cpp
Using cached library dependencies for file: C:\arduino-1.8.5\hardware\arduino\avr\libraries\Wire\src\utility\twi.c
"C:\arduino-1.8.5\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.8.5\hardware\arduino\avr\cores\arduino" "-IC:\Users\USER\AppData\Local\Arduino15\packages\rambo\hardware\avr\1.0.1\variants\rambo" "-IC:\arduino-1.8.5\hardware\arduino\avr\libraries\SPI\src" "-IC:\arduino-1.8.5\hardware\arduino\avr\libraries\Wire\src" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Repetier.ino.cpp" -o "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\arduino-1.8.5\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Commands.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Communication.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Eeprom.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Extruder.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\HAL.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Printer.cpp.o
"C:\arduino-1.8.5\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR   "-IC:\arduino-1.8.5\hardware\arduino\avr\cores\arduino" "-IC:\Users\USER\AppData\Local\Arduino15\packages\rambo\hardware\avr\1.0.1\variants\rambo" "-IC:\arduino-1.8.5\hardware\arduino\avr\libraries\SPI\src" "-IC:\arduino-1.8.5\hardware\arduino\avr\libraries\Wire\src" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Repetier.ino.cpp" -o "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Repetier.ino.cpp.o"
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\SDCard.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\SdFat.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\gcode.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\motion.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\ui.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\libraries\SPI\SPI.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\libraries\Wire\Wire.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\libraries\Wire\utility\twi.c.o
Compiling core...
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\wiring_pulse.S.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\WInterrupts.c.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\hooks.c.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\wiring.c.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\wiring_analog.c.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\wiring_digital.c.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\wiring_pulse.c.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\wiring_shift.c.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\CDC.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\HardwareSerial.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\HardwareSerial0.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\HardwareSerial1.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\HardwareSerial2.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\HardwareSerial3.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\IPAddress.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\PluggableUSB.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\Print.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\Stream.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\Tone.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\USBCore.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\WMath.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\WString.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\abi.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\main.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\new.cpp.o
Using previously compiled file: C:\Users\USER\AppData\Local\Temp\arduino_build_446917\core\core.a
"C:\arduino-1.8.5\hardware\tools\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections,--relax -mmcu=atmega2560  -o "C:\Users\USER\AppData\Local\Temp\arduino_build_446917/Repetier.ino.elf" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Commands.cpp.o" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Communication.cpp.o" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Eeprom.cpp.o" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Extruder.cpp.o" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\HAL.cpp.o" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Printer.cpp.o" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\Repetier.ino.cpp.o" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\SDCard.cpp.o" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\SdFat.cpp.o" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\gcode.cpp.o" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\motion.cpp.o" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\sketch\ui.cpp.o" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\libraries\SPI\SPI.cpp.o" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\libraries\Wire\Wire.cpp.o" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917\libraries\Wire\utility\twi.c.o" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917/core\core.a" "-LC:\Users\USER\AppData\Local\Temp\arduino_build_446917" -lm
"C:\arduino-1.8.5\hardware\tools\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0  "C:\Users\USER\AppData\Local\Temp\arduino_build_446917/Repetier.ino.elf" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917/Repetier.ino.eep"
"C:\arduino-1.8.5\hardware\tools\avr/bin/avr-objcopy" -O ihex -R .eeprom  "C:\Users\USER\AppData\Local\Temp\arduino_build_446917/Repetier.ino.elf" "C:\Users\USER\AppData\Local\Temp\arduino_build_446917/Repetier.ino.hex"
Using library SPI at version 1.0 in folder: C:\arduino-1.8.5\hardware\arduino\avr\libraries\SPI
Using library Wire at version 1.0 in folder: C:\arduino-1.8.5\hardware\arduino\avr\libraries\Wire
Sketch uses 135182 bytes (52%) of program storage space. Maximum is 258048 bytes.
Global variables use 7309 bytes of dynamic memory.
An error occurred while uploading the sketchFortunately Arduino 1.8.5 will compile and upload FW version 0.92.2 date 20161014
So I am back where I started.
Does anyone know what version of Arduino will compile and upload The latest version of firmware?
