ABS clyinders look like hour glass
mmchupp
Post by mmchupp »
Hello.
Any suggestions of what to try to fix this issue?
As the print gets taller, straight vertical walls start "pulling" in.
What should be a cylinder, looks more like an hourglass. :|
I'm printing ABS on ROSTOCK MAX
Bed at 110, Nozzle at 228
Perimeter speed is 45mm/s
Infill at 40mm/s
Re: ABS clyinders look like hour glass
You need to enclose the printer - moving air is causing the problem. Even walking by the printer can ruin an ABS print.
