V3 to V3.2 - Stepper Motors?
This forum is for discussions specific to the Duet-equipped RostockMAX v3.2 3D printer.
cloneit3d
Post by cloneit3d »
Why does the kit instruction speak of new stepper motors? The old look to be the same as the steppers sold and used now. My V3 has gotten very little use as I wanted a production machine to function better out of the box and sadly that has not been my experience to date. I am thinking of buying the upgrade kit in hopes of a better experience. How do folks like the V3.2?
Thank you in advance for your time and responses.
Best Regards,
Tim
Home brew cartesian running a 32bit Smoothie and E3dV6
Rostock V3
Tormach 1100PNC
Home brew CNC Plasma
Other projects always in the works
Self designed plasma cutting table running Mach3
Orbot Hadron running and E3d 6, Smoothie on an Azteeg Mini, LCD, fully adjustable glass bed of my design with a silicone mat heater.
Prtrbot Simple Metal
Table top CNC running Mach 3
Re: V3 to V3.2 - Stepper Motors?
You can opt to buy .9 degree steppers as part of the upgrade kit.
briankb
Post by briankb »
two related questions, what was the degree (resolution?) on the original v3 stepper motors if not .9?
What is the benefit of the .9 degree steppers?
DeltaCon
Post by DeltaCon »
The originals were 1.8.
The benefit? double resolution.
dc42
Post by dc42 »
I covered the benefits of 0.9deg motors including before and after prints in my blog at https://miscsolutions.wordpress.com/201 ... a-printer/. This was on my own Kossel derivative, not on a SeeMeCNC printer, so your mileage may vary.
MrWiggum
Post by MrWiggum »
Speaking about stepper motors, which one would be better for the v3.2 EZR Struder. I bought the upgrade from v3 to v3.2 and my old V3 EZR Struder is failing, so i need to buy a new one but its asking if i want a stepper motor with the EZR Struder. Should i get a new stepper motor and if i should, should i get the 1.8 or the 0.9 to go with the new v3.2.
Horvaticus
Post by Horvaticus »
I recently upgraded from the 3 to the 3.2, and purchased an extra 0.9 stepper motor for my extruder. It makes setup a little simpler, and my results were similar to @dc42. When I asked for a dual extrusion kit for xxx-mas, I also asked for the 0.9 version as well. Been running like a charm when I do my part!
Return to “RostockMAX v3.2”
