Printer: Rostock Max V2 with He280
I'm think I have a diagnosis for this one but I'm hoping I'm wrong
So I was a few hours into printing a long t-glass print teps set to 240 and 75 when the printer stopped and screen turned off. The only thing that's was still running was the psu fan. I pulled it apart and tested it with a multimeter and get 12v on the connector going into the Rambo, 0 ohms across all the fuses on the board and no lights on anything. I'm guessing it's a dead board.
Is there a more thorough way check this for sure and if I am right about the dead board, anybody got a suggestion on why it failed?
Solution: Testing the fuses in the board caused them to all test fine despite one of them being blown. Thanks to Mac the Knife for pointing this out.
No Power to Rambo [Solved]
Re: No Power to Rambo
I would carefully check the power input terminal block and make sure it's tight and not discolored. Were you printing via SD card or USB?
You did remove the fuses from the board when you checked them?
Good point - if you check the fuses in-circuit, you can get a false "good" indication.
Nope. This was the problem. the top tiny fuse mounted directly left of the power input to the board was blown but read fine when tested in the board. Thanks for the tip. Now I have to figure out why it blew. Could a short in one of the layer fans have blown it?Mac The Knife wrote: ↑Mon May 06, 2019 8:13 am You did remove the fuses from the board when you checked them?
It's certainly possible.
