So I have had some really good results with my Rostock V4 all it needed was an enclosure for better ABS results.  Soon I will experiment with nylon.
I posted the files and my terrible instructions on thingiverse for all to use.
The enclosure does not interfere with the print head or the glass holding clamps.
https://www.thingiverse.com/thing:3787990
 I have to thank SEEMECNC for posting the cad files for the base and top online.  It was nice being able to import them into fusion 360 and drawing my design around them, it saved me so much measuring then trial and error.
							Enclosure for the V4
Re: Enclosure for the V4
Nicely done!
				Ramrodzergy
- Noob
Thanks for posting this I printed the top and bottom in PETG and going to use reflective bubble wrap so I can print a new design in ABS ( I found the CAD files you mentioned) My design is going to be a little bit wider and use the edges for support. Also I plan on adding chamber thermal regulation to it  and possibly a heater if the chamber needs it.
