SE300 Heater Power Problem
ROvermeyer
Post by ROvermeyer »
I built a Max V3, which I upgraded to a V3.2. The SE300 had the hotend power problem where it overheated the power connector for the hotend heater. I installed the SE300 Power Connector Upgrade Kit to fix this problem. I am again having hotend power problems and I found that the new power connector on the circuit board is broken, see attached photo. I see that SEEMECNC no longer sells the upgrade kit. Does anyone know what the part number of the 2 pin Molex receptcale is?
Re: SE300 Heater Power Problem
Contact support, they can help you out with that.
ROvermeyer
geneb,
I posted this here and contacted support, support has responded.
Thanks.
Bob O.
Return to “RostockMAX v3”
