I added a Wham Bam to my Rostock Max v2 with the HE280 upgrade. When I tried to auto-level it, the hot end would slam down on the Wham Bam and after approximately 3 tries would just keep pushing down causing me to have to cut the power. I went into the EEPROM settings and while fiddling with it, I managed to remove a setting and add another causing the printer to think the bed is way wider than it is. I would just like to reset everything to defaults but I don't know how. Please help!
Thank you!
I need the Default EEPROM settings
Re: I need the Default EEPROM settings
In case anyone is interested, I received the following from SEEMECNC about this and it worked for me:
You can factory reset by sending M502 first, then M500 to save. Power cycle after these commands.
You can make a gcode program in a text editor, name it somethin like reset.gcode and has 1 second pauses
M502
G4 S1
M500
G4 S1
Then turn off the printer, and turn on once the power supply is fully discharged.
M502
G4 S1
M500
G4 S1
Glad to hear you got it sorted! I've got a WhamBam plate waiting to be installed on my BOSSDelta 300. Maybe I'll get to it over vacation.
