I switched out my long bowden tube for a direct drive extruder on my Rostock Max v2 with 713maker effector. In the process I raised the extruder 25mm and rotated it 20º to help it clear the arms, and then when it still hit an arm at an extreme point within the build envelope I printed 13mm extensions for each of the arm attachment points to effectively enlarge the effector plate.
In case anyone has a similar setup and wants the STL files or a link to the Onshape project to alter, it's all here:
Thingiverse link: raised Orbiter 2 mount and effector extension for 713maker Rostock effector plate
These may not be the world's prettiest or most-advisable mods (they were printed with the prior miscalibrated extruder and I melted the mount a little much when getting a heat-set insert into place), but the setup in these photos has now been functional and very sturdy for several weeks of printing.
Orbiter v2 mount and extensions for 713maker Rostock effector
- Screenshot 2024-01-22 at 6.01.56 PM.png (684.18 KiB) Viewed 26984 times
- Orbiter v2 mount.png (172.17 KiB) Viewed 26984 times
- IMG_7509.jpeg (340.14 KiB) Viewed 26984 times
- IMG_7507.jpeg (274.8 KiB) Viewed 26984 times
