clogged nozzle
This forum is for discussions specific to the Duet-equipped RostockMAX v3.2 3D printer.
kuper
clogged nozzle
Post by kuper »
hello,
I have an extruder skipping steps because clogged nozzle.
the nozzle is clogged because of the small chamfer in the nozzle and the heat break,
which causes the filament to stuck in this chamfer.
Does anyone have any idea how to solve it?
photos attached,
thank you.
WhatsApp Image 2024-01-25 at 20.29.11.jpeg (91.81 KiB) Viewed 29175 times
WhatsApp Image 2024-01-25 at 20.29.11 (1).jpeg (108 KiB) Viewed 29175 times
WhatsApp Image 2024-01-25 at 20.29.11 (2).jpeg (77.29 KiB) Viewed 29175 times
WhatsApp Image 2024-01-25 at 20.29.12.jpeg (85.19 KiB) Viewed 29175 times
Re: clogged nozzle
The chamfers aren't the cause of the jamming. Molten plastic will flow right past those.
The most common cause of jams is related to printing too fast for the current hot end temperature. A failed cold-section fan can also be a factor.
Return to “RostockMAX v3.2”
