Latest revision of the documentation?
davidsf
Post by davidsf »
Hi there. I was wondering if anyone knew if there was an update to the documentation. We have been using the (near final) version of The Rostock MAX Assembly Guide, 2nd Edition, Version 1.00, May 8th, 2013. Is that the latest or is the a subsequent revision.
Thank you!
Re: Latest revision of the documentation?
See here for the latest:
http://www.geneb.org/rostock-max/Rostoc ... -Guide.pdf
The latest is always kept under the Official Docs topic.
davidsf
Post by davidsf »
THANKS!!!
davidsf
Post by davidsf »
I am surprised that they don't post each subsequent revision of the docs on the SeeMeCNC website. If they do, it is not obvious where it is....
Because the location never changes (well it will once github fixes their stupid problem with large files).
Note that the manual IS NOT completed yet. I took a short break after the calibration chapter was done and I started working on the "your first print" chapter this week.
geneb wrote:Because the location never changes (well it will once github fixes their stupid problem with large files).
With all you've done to create the manual I think you deserve a "short" break. Good job!
davidsf
Post by davidsf »
Yes thanks Gene for all of your hard work. The rev of the manual answers many questions that we had. THANKS!
You're quite welcome guys - I'm happy to be doing the work.
I may get the first print chapter nailed down this evening. :)
Return to “Rostock MAX”
