Hi there...we just downloaded v1.05 of the documentation and is says:
"A quick note on the RAMBo, the controller for your Rostock MAX. The RAMBo is static
sensitive, so please don't take it out of the static bag it ships in until you're ready to use it."
We already took ours out of the bag (since this was not in the prior revisions of the documentation). What can we do to remediate this?
question regarding the RAMBo?
Re: question regarding the RAMBo?
You should be fine. The documentation gives you the best approach which is not to remove the card until you are ready to use it.
The is the best approach but as long as you did not zap the card with some static electricity, the card should be fine.
Do the install, you will then know if there are issues with the card but my bet is on the card working fine.
Thank you. Very helpful!
