I'm working on putting these two together into a single unit...
Think MR Fusion from Back to the Future. Drop in plastic bottles, grocery bags, whatever and print stuff. Any thoughts?
-Doc
Rostock plus Extruderbot
doctorgonzo
Re: Rostock plus Extruderbot
Flux capacitor?
Short of matching up feed speeds or accommodating a mismatch, you're on to something!
http://dropc.am/p/KhiI1a
doctorgonzo
So, a process that makes high-quality filament on the spot is required.
Here's a proposed design for a plastic recycler:
1. Vacuum and heat are good for removing moisture and contaminants.
2. A chamber has to be developed for #1
3. An extruder, frame and mount must be printed, purchased, or machined.
4. Flux capacitor, whozzle-wozzle valve and blinker fluid, Madaffle-ator And some gizmo-gadgetronics.
5. Kickstarter
6. Doable.
5. Kickstarter
6. Doable.
need magic smoke also
Boss 1 - "I'm tiered of arguing with you! You come up with the MOST Stupid-Outlandish-Impossible way to do something & then you walk out into the shop and DO IT and IT WORKS. Its no fun anymore."
Boss 2 - "Huh? Chris is a Ninja?"
