any one know how to get a mk2 heat bed to work with rambo
spart
Post by spart »
not to sure if i got to do some kinda setting in arduino but every time i kick in the hotbed my power shuts off when i hit the button in repetier host , the hot end working great now that i dont have the resisters wired back to them self {dah} tested hotbed with 4 inch wire right into mosfet out put and it dies soon as i hit button and got to do a reset
any one know am i over juicing and got to set something lower in arduino?
Re: any one know how to get a mk2 heat bed to work with ramb
What resistance do you measure from the bed?
Generally if the PSU is shutting down it's either a short, or trying to pull too much power from the PSU.
spart
Post by spart »
what can i safely trun the power up to and not fry my rambo borad i have a 12v 20a power supply got it set to 12.90 now just seems to cough out when i hit the button
cambo3d
Post by cambo3d »
got photos of your heatbed wiring. did you solder connections to it? (the heatbed that is)
spart
Post by spart »
the hot bed has a 1K Ohm resistor on it thats all i know
spart wrote:the hot bed has a 1K Ohm resistor on it thats all i know
That's just a pull-up resistor for the LED.
Most beds are in the 1.2 to 1.5 OHM range, you need to measure it with a meter. Some I've seen are below 1 OHM and this can cause issues.
Honestly it's most likely that you're just pulling to much current from the PSU, either a short or the PSU is just not quite up to it's rating.
spart
Post by spart »
12.14 coming out at the mosfet output heated bed post when i hit the button is that right
spart
Post by spart »
meter set to 200 ohm setting iam getting 2.0 on the post of hotbed
You need to measure it disconnected from the RAMBO.
spart
Post by spart »
ya i did, i un-sodered the hot bed and metered , it came to 2.2 with out wires and i put new ones on and getting same 2.2 ohms
cambo3d
Post by cambo3d »
what i was trying to see was if you shorted the solder connections.
pic would help.
spart
Post by spart »
some pics. this hotbed came with pre sodered resister and led.
3dpics2 101.jpg (6.37 KiB) Viewed 13307 times
3dpics2 095.jpg (6.18 KiB) Viewed 13307 times
3dpics2 094.jpg (4.97 KiB) Viewed 13307 times
cambo3d
Post by cambo3d »
hard to tell anything from those pics
spart
Post by spart »
hot bed rated for 10amp would changing the fuse down to 10 from 15 work
No the odds are the issue is the PSU.
spart
Post by spart »
ya might be going to look for new one, not to sure seams like a lot of people having same problem. i did notice when i first did it that the led resister did flash red when i first hooked it up so think i am over powering it, took off resister and the led and that didnt fix it just in case i cooked it. so doing some home work on it seams like iam not the only one with this problem with this 1.1b board. i am getting full power Scotty but the ship cant handle it lol, just triping power off, i know my mk2 board is rated for only 12v 10 amps so going to throw a 10 amp in tomorrow see if i can get the fazers to fire or make a fire lol hope that works then this will be a ( fully operational printing station )
Captain Starfish
Post by Captain Starfish »
First post on this forum and a +1 to the issue.
Will disconnect the Onxy and measure its impedance and the voltage being spat out of the RAMBO when I switch the bed on.
Have updated the firmware to the latest version from the SeemeCNC website.
Dammit, I wanna play with my new toy!! :)
Captain Starfish
ooops. :oops:
Went a little overboard with the bed wires and they didn't want to fit into the RAMBO screw block, guessing there were a couple of strays which were shorting. Cleaned up and all happy now.
And another ooops for posting in the wrong forum...
