PTFE tubes
jake
PTFE tubes
Post by jake »
I warped, ruined and split my PTFE tubes and wanted to replace both of them. Ware can I get a replacement please.
kbob
Re: PTFE tubes
Post by kbob »
Rostock MAX uses PTFE tubing in three places.
  • The Bowden tube is PTFE.
  • The thermistor leads are sleeved in PTFE.
  • The hot end resistor leads are sleeved in PTFE.
McMaster-Carr sells PTFE tubing in many sizes. For the thermistors, 5335K9 is the part number. For the resistors, it's 5335K13. I don't know the part number for the Bowden tube, but you want 2 mm ID.
SeeMeCNC also sells tubing for the Bowden tube.
http://shop.seemecnc.com/Teflon-Tubing- ... gs_c10.htm
jesse
Re: PTFE tubes
Post by jesse »
eBay has them too but not transparent
tom10122
Re: PTFE tubes
Post by tom10122 »
It doesn't need to be transparent to work
jake
Re: PTFE tubes
Post by jake »
I did not realize that. I am talking about the tubes inside the hot end.
Re: PTFE tubes
You know that the outer PTFE tube in the hot end is split on purpose, right?
