Damn you shrinkage! (trivial I know)
So on a hollow cube ( .2mm layers, abs) my first layer prints spot on, a 10 mm cube is 9.97, then you go up 20 layers and the plastic pulls in so the cube is ~9.82mm. Everything is lined up, no skewing, good adhesion on layers, good adhesion to the bed...the only thing is that it contracts as it moves away from the bed (it is consistant after that). Is there anything to change to counter that effect?
Re: Damn you shrinkage! (trivial I know)
I think you need to set your infill to 60% or so. (-:lordbinky wrote:So on a hollow cube ( .2mm layers, abs) my first layer prints spot on, a 10 mm cube is 9.97, then you go up 20 layers and the plastic pulls in so the cube is ~9.82mm. Everything is lined up, no skewing, good adhesion on layers, good adhesion to the bed...the only thing is that it contracts as it moves away from the bed (it is consistant after that). Is there anything to change to counter that effect?
- astroboy907
No offense but your avatar is the perfect representation of this post...lordbinky wrote:So on a hollow cube ( .2mm layers, abs) my first layer prints spot on, a 10 mm cube is 9.97, then you go up 20 layers and the plastic pulls in so the cube is ~9.82mm. Everything is lined up, no skewing, good adhesion on layers, good adhesion to the bed...the only thing is that it contracts as it moves away from the bed (it is consistant after that). Is there anything to change to counter that effect?
My Heatware!.Flateric wrote: Black ABS, weak part, bizzare holes, bad layer adhesion, loss of details. Loss of sanity.
Hmmm.... Nope, don't see it.
Psh, but then it wouldn't be a hollow cube.kbob wrote:I think you need to set your infill to 60% or so. (-:lordbinky wrote:So on a hollow cube ( .2mm layers, abs) my first layer prints spot on, a 10 mm cube is 9.97, then you go up 20 layers and the plastic pulls in so the cube is ~9.82mm. Everything is lined up, no skewing, good adhesion on layers, good adhesion to the bed...the only thing is that it contracts as it moves away from the bed (it is consistant after that). Is there anything to change to counter that effect?
