rock stocks 4th print ever
wildideas1
Post by wildideas1 »
well my son and i decided on adding the Rockstock to our table when he was 9 we built the H-1 and now for his 11th b-day i said lets build the rock stock, 1,2nd print failed due to extruder coils going kaput snagged from H-1 and up and running again 3rd was beauty and sliced with on board slicer using Gene's manual set up configs, 4th was using kisslcr configs by mhackney's KISS settings. although i dint change anything in settings of the configs the print tells me allot and i will tweak and retry again. model is single wall and hollow. I will re-do with double wall and should be perfect. machine is completely stock with added triple ezstruder top spool holder set up.
4th print finishing on bed
left side
left side
right side
right side
will you look at that mid section  aahh
look women get cellulite even in plastic
Re: rock stocks 4th print ever
Very nice print!
Just a point - while "Rockstock" sounds pretty cool, it's actually a Rostock MAX. :D
wildideas1
Rostock is correct midnight lack of sleep and spellcheck does not help
realcomix
Post by realcomix »
Where did you find that file!?
wildideas1
Thingaverse 3 different styles labled lady bust
They are also called Pink Panther Woman on Thingiverse.
