rock stocks 4th print ever
wildideas1
well my son and i decided on adding the Rockstock to our table when he was 9 we built the H-1 and now for his 11th b-day i said lets build the rock stock, 1,2nd print failed due to extruder coils going kaput snagged from H-1 and up and running again 3rd was beauty and sliced with on board slicer using Gene's manual set up configs, 4th was using kisslcr configs by mhackney's KISS settings. although i dint change anything in settings of the configs the print tells me allot and i will tweak and retry again. model is single wall and hollow. I will re-do with double wall and should be perfect. machine is completely stock with added triple ezstruder top spool holder set up.
Re: rock stocks 4th print ever
Very nice print!
Just a point - while "Rockstock" sounds pretty cool, it's actually a Rostock MAX.
wildideas1
Rostock is correct midnight lack of sleep and spellcheck does not help
Where did you find that file!?
wildideas1
Thingaverse 3 different styles labled lady bust
They are also called Pink Panther Woman on Thingiverse.
