Rostock Max Axis Problem
RostockLiverpool
Post by RostockLiverpool »
I have built the Rostock Max kit which came with all of the electronics. The board I have is the RAMPS 1.4 and Arduino. I am using the Repetier firmware and I have configured it so that everything appears to be working correctly apart from one thing.
When I request a movement down in the z axis all of my cheapskates move down - no problem. However, when I request a movement up in the z axis the x and y cheapskates move up but the z moves down!
I have switched the x and y motors round and the problem moved to the y axis instead.
All of my limit switches work correctly and have been checked using M119.
Re: Rostock Max Axis Problem
RostockLiverpool wrote:I have built the Rostock Max kit which came with all of the electronics. The board I have is the RAMPS 1.4 and Arduino. I am using the Repetier firmware and I have configured it so that everything appears to be working correctly apart from one thing.
If you swap the first two wires on the Z axis plug it would change the direction of the Z motor.
Have you tried to do that? Make sure you have the power off when working on the wiring!
RostockLiverpool
I have tired that. It just reversed my problem. When I asked the z-axis to move up, all the cheapskates moved up. When I asked the z-axis to move down, X and Y moved down but Z moved up.
RostockLiverpool
This is the firmware that is currently on my board
Repetier-Firmware-master.zip
(2.3 MiB) Downloaded 176 times
RostockLiverpool wrote:I have tired that. It just reversed my problem. When I asked the z-axis to move up, all the cheapskates moved up. When I asked the z-axis to move down, X and Y moved down but Z moved up.
I need to better understand what is happening. Please explain the problem again. What is supposed to happen and what is actually happening.
RostockLiverpool
On the Manual Control of the Repetier Software if I click -Z all of the cheapskates move down and so the effector platform moves down in Z.
If I click +Z the X and Y cheapskates move up and the Z moves down.
The Z cheapskate only moves in one direction. If I issue the G28 code then X and Y head up to the limit switches but Z moves down towards the print-bed.
I have tried switching the wires round on the Z motor and that caused it to only move up.
I have tried inverting the axis in the software and that caused the Z motor to only move up.
I connected the Y motor to the Z motor pins, and then the Y motor was only capable of movement in one direction.
Sounds like a bad driver on the Ramps board. You can try to swap the driver board to a different axis, then that axis should move in one direction.
RostockLiverpool
Tried swapping them round and it hasn't solved my problem. I swapped Z and Y. Y still runs as it should. Z does not.
RostockLiverpool wrote:Tried swapping them round and it hasn't solved my problem. I swapped Z and Y. Y still runs as it should. Z does not.
Perhaps a bad motor on Z or a problem with the firmware. You already said that when you swapped the wires the motor ran in the opposite direction so
that pretty much rules out a bad motor. I guess at this point I would try to install a fresh copy of the firmware on the Ramps. What is happening makes
no sense electronic wise.
You might also inspect the Ramps board and ensure that the soldering connections to the Z axis area look okay.
RostockLiverpool
PROBLEM SOLVED
It turns out that pin 48 on my Arduino board had failed. It was reading high and not changing. Pin 48 controls the Z direction.
1 new Arduino and the problem has now disappeared.
Thank you for your help Eaglezsoar!
RostockLiverpool wrote:PROBLEM SOLVED
You are welcome, excellent troubleshooting on your part. That was a tough one to diagnose.
Happy Printing!
