I purchased, assembled and calibrated a Rostock Max as part of the indiegogo campaign last year. I have upgraded to the ONYX bed, tricklaser arms and the EZ-Struder. I have the top mount flat pack however i have not assembled or lengthened the wires to do so. I have not upgraded the hot end (this was next on my list). The RAMBO board is the first gen with zero problems. Basically i have little to no time (it is calibrated and has been problem free as far as it can be) I have printed only black ABS though i have a roll of white lying around. The trick laser arms cured the delta arm blues that so many suffered from early on (myself included, it was a nightmare until this install and became quite enjoyable to use after this)
I will post pics if required or send them direct to interested parties. I would love to hang onto her but with school, work full time and life, id rather someone else have the joy and the machine so that it does not sit idle in the closet all alone. I have had no problem other than the delta blues and of course the usual frustrations with blobbing from poor retract settings. It works as should, i only wish i had the time to use it as deserved.
Please make me a reasonable offer, all will be entertained. ~1000.00 would be a nice number
I am located in Columbia CT. the machine could be demo'd if required, i would consider shipping for the right price but pickup would be the best option.
after assembly and a few hundred dollars in upgrades i am just looking for a reasonable offer to a good home.
email at: ktmseth at gmail dot com as I check the forums when i can but it is not often enough.
Thanks,
-Seth
