I've been attempting to print the attached fan shroud file and it seems to hang at the same spot each time.
Unfortunately, I print it from the SD so I can't say what layer it's on when it stops but I think it's around the 30-40% range. If anyone feels like trying it out, I'd love to know whether the problem is limited to just my MAX or whether it's in the file itself. The model imports into Repetier cleanly and slices just fine.
Maybe I'll go kick off a print from Repetier so I can see what layer it quits on. A quick read through the Gcode didn't reveal anything, but it's pretty large to just scan.
Dave
Bad GCode?
Re: Bad GCode?
3 downloads but no one has reported back anything. I don't know why they haven't given you the results.
Re: Bad GCode?
I just wanted to look at the code...haven't run it or anything.
