Broken bowden mount
int2str
Broken bowden mount
Post by int2str »
Broke the bowden mount on my ORION hotend last night :(
Went to remove the feed tube to change filament and somehow ended up breaking the blue plastic retainer. It won't hold the tube in anymore.
The good news is that I already have a E3D in the mail to be delivered today.
Just for future reference, what's the best way to prevent breaking these bowden mounts?
Thx
Re: Broken bowden mount
The only time I've EVER seen one of those break is when a Steve's Extruder pushed the filament so hard it blew the teeth out of it.
You know you're supposed to push down on the blue ring to release the tube, right? :D
You may have simply gotten a dodgy one.
Lochemage
Post by Lochemage »
I've had about 6 of these break on me so far, but not since I replaced my extruder. For some reason, the stock extruder requires a lot more filament pressure/force to print, and that constant pressure causes those teeth to tear right out eventually.
- Lochemage
My super cool build stories: Rostock MAX, GUS Simpson
"Give a man a compliment and he'll be all, 'Yeah, I've been working out.' Teach a man to fish for a compliment and he'll be all, 'I feel SO fat.'" - Bob FM
int2str
Post by int2str »
Replaced the hot-end with an E3D, but now the extruder side just popped out.... *sigh*.
Too bad the bowden mount that came with the E3D won't fit the extruder....
int2str wrote:Replaced the hot-end with an E3D, but now the extruder side just popped out.... *sigh*.
With modifications it probably would fit on the extruder. The ones used by SeemeCNC uses M5 threads and
the E3D ones use 1/8" threads. You can buy the bowden mounts from Filastruder now also, I just bought 6
of them so I can have some spares. They ship immediately but the USPS held them for 2 days before they
decided to ship them. I guess because it the time of the year where they are really busy or it could be they
are the most inefficient shipping Company on the planet. Filastruder is great, they ship the same day or the
next day, highly recommended for anything E3D related.
jmpreuss
Post by jmpreuss »
For the record one of mine busted on my Orion too (happened after a filament jam)
cope413
Post by cope413 »
I had lots of them break pre-E3D - at least 4-5 in 3-4 months - both the stock ones from SeeMe, and replacements from Mcmaster. Granted I'm a heavy user, but still, definitely frustrating to lose a print because of a little $2 part. The ones E3D ships are much better in quality - I've got at least 400 hours on mine and not one has failed yet. You can drill and tap the aluminum piece coming out of the EZstruder to handle the different threading, and I would recommend doing so if you want worry-free printing.
And for the record, it's heavy retracts that kills the connectors
cope413 wrote:I had lots of them break pre-E3D - at least 4-5 in 3-4 months - both the stock ones from SeeMe, and replacements from Mcmaster. Granted I'm a heavy user, but still, definitely frustrating to lose a print because of a little $2 part. The ones E3D ships are much better in quality - I've got at least 400 hours on mine and not one has failed yet. You can drill and tap the aluminum piece coming out of the EZstruder to handle the different threading, and I would recommend doing so if you want worry-free printing.
I believe the ones from E3D are 1/8" but I don't know the thread pitch, do you know what tap to use or should I just contact Sanjay?
cope413
Post by cope413 »
http://www.grainger.com/product/JOHN-GU ... ctor-1WTX2
It's BSPT threading, so it's a little wonky, but here's a link with all the info needed...
http://www.newmantools.com/taps/bsp.htm
Oh, and if you purchase them from Grainger (or anywhere else) - all you need to do is remove the push-connector, and ream out the inside so that the PTFE can slide all the way through
Taylor thanks for the info but Holy Cripes Almighty did you see the prices on just one 1 tap?
Close to $44 for 1 tap. Without shipping added.
So if I understand it correctly I need a 1/8" BSPT tap that costs a freaking fortune.
Also this is a question I have had since I have received the Bowden E3D (have not installed yet) the connector is a hex shaped threaded part that has
no teeth and there is a small top piece that pushes though the top. What actually holds the Bowden tube in place, the upper part that pushes in and
holds via friction with the tube or is it just hope and a prayer?
With the price of a BSPT tap I may decide just to tap my old E3D hotends with a 5mm tap and use the ones that everyone hates (with the teeth)
I had a virtual heart attack when I saw the price of one tap. Please send some heart meds next time you post a message like that.
One more question to add to the list, that grainger link you gave certainly look exactly what E3D uses, have you ordered them to be sure?
That's it with this message I need to lay down and try to mend my ticker.
Lochemage
Post by Lochemage »
I actually found an alternative push fit connector that works similar to the E3D one, except it fits the size of the SMC kind. I too didn't want to drill and tap a new size
I ordered it from here http://www.tridprinting.com/Hot-Ends/#3 ... it-Fitting
- Lochemage
For anyone interested, the drill bit needed for tapping with the 1/8" BSPT is 21/64"
The best price I found for the tap itself is Amazon.com at a price of $30.09 (Prime Shipping)
The tap is listed as
Dormer E550 High-Speed Steel Pipe Tap, BSPT, Uncoated (Bright) Finish, Round Shank With Square End, Modified Bottoming Chamfer, 1/8"-28 Thread Size
cope413
Post by cope413 »
I haven't looked into it much, but it appears that mcmaster has them for $16
http://www.mcmaster.com/#bspt-taps/=pwnw6w
cope413 wrote:I haven't looked into it much, but it appears that mcmaster has them for $16
I owe you man, thanks for finding that. My heart has now fully recovered and I am ordering that tap today.
All I have to do now is figure out how to drill a straight 21/64" (8.4mm) hole in my 2 old E3D's. The way I shake
the hole will come out looking as straight as a politician. Maybe I can figure out how to mount them in my drill
press. Anyway thanks for finding that tap! In payment for the find dial 330-3BR-LOVE and ask for Anna, she
will take you to the heavenly heights, only in your dreams however. :)
I have just placed my order to McMaster and will have the tap and drill bit on Tuesday.
I appreciate cope413 finding them at a decent price. Well, time to fly away and find
a juicy mouse to eat.
