~$2000 gamble....
int2str
~$2000 gamble....
Post by int2str »
Printed up this bracket last night and put it up on the wall:
For reference, the bracket is 23cm wide. I printed it "on end" and again is almost the tallest object the ORION can print.
What is it for? Well, that's the ~$2000 gamble :)
I'm betting about that much money that the printed ABS bracket is strong enough to hold this:
:ugeek:
Again for reference, the main rotor blade is 55cm in length.
I still have to print a tail fin stand-off, but otherwise I'm very happy with how it turned out.
Lochemage
Re: ~$2000 gamble....
Post by Lochemage »
I don't know if I'd go so far as to say you're gambling an entire 2k... Sure, the whole thing could be worth that... but a simple drop to the floor probably won't do THAT much damage.
Still, nice way to mount it though.
- Lochemage
My super cool build stories: Rostock MAX, GUS Simpson
"Give a man a compliment and he'll be all, 'Yeah, I've been working out.' Teach a man to fish for a compliment and he'll be all, 'I feel SO fat.'" - Bob FM
int2str
Post by int2str »
Lochemage wrote:I don't know if I'd go so far as to say you're gambling an entire 2k... Sure, the whole thing could be worth that... but a simple drop to the floor probably won't do THAT much damage.
Heh, yes, I may have been a bit overly dramatic there ;)
Hopefully I'll never find out.
Blade-Breaker
Post by Blade-Breaker »
Looks good. I bet you could almost hang from it.
Toyguy
Post by Toyguy »
Is the STL available? I could print a few of those for my brother :)
Eric
Post by Eric »
No point in making them stronger than the wall...if the screws pull out of the wall, it's not the brackets fault.
int2str
Post by int2str »
Toyguy wrote:Is the STL available? I could print a few of those for my brother :)
STL + FreeCAD file attached.
The STL will most likely be useless since the skid-holes are exactly 20cm apart for this specific heli. You'll have to know what Heli he has or how far apart the skids are.
Then you can easily adjust the dimensions in the FreeCAD file.
HeliBracket.zip
(33.09 KiB) Downloaded 373 times
FYI: "If the wings are moving faster than the fuselage, you're in a helicopter and are therefore unsafe."
:D :D :D
bubbasnow
Post by bubbasnow »
geneb wrote:FYI: "If the wings are moving faster than the fuselage, you're in a helicopter and are therefore unsafe."
:D :D :D
says a fixed wing guy... rotary wing FTW!
dbarrans
Post by dbarrans »
What's worse is most of the time the wings aren't even moving in the same *direction* as the fuselage. :-)
- dan
barry99705
Post by barry99705 »
:D :D :D
Here! Here! :D
says the guy that flew in a flying gas station with 190,000 pounds of fuel on board...
