printing text on parts
lasermike
Post by lasermike »
what are some successful text fonts that have been printed on parts. font style, raised or lowered height, and size.
Mike Spray
bubbasnow
Re: printing text on parts
Post by bubbasnow »
when i do text i like to cut rather then extrude the letters. with a small nozzle and 1 perimeter you can get some good resolution. as for the type of fonts, i usually stick with bold block style i haven't tried any fancy cursive.
wildideas1
Post by wildideas1 »
Would like to what you've done can you post some pic of what you have done
Thks
Ian
jmpreuss
Post by jmpreuss »
Celtic Knot font
wildideas1
I forgot to ask how are you doing the set up to print. they look darn cool.
I agree with wildideas1 and would like to know how you do it.
Especially the raised text.
Batteau62
Post by Batteau62 »
I've found that generating text in "Inkscape" and exporting it to SCAD with that path converter works really well. I made this name plate in about five minutes :D
I added the back plate in Inventor Fusion.
Eaglezsoar2.stl
(1003.13 KiB) Downloaded 328 times
No guarantees on how it will print ;)
bubbasnow
Post by bubbasnow »
in solidworks
make your object on a plane
[img]https://lh6.googleusercontent.com/-trxT ... apture.PNG[/img]
[img]https://lh5.googleusercontent.com/-9HPA ... apture.PNG[/img]
extrude it, on this i chose revolve
[img]https://lh6.googleusercontent.com/-2Heo ... apture.PNG[/img]
make a new sketch on a plane, drag a construction line first then write the text on that line
[img]https://lh6.googleusercontent.com/-Gm-B ... apture.PNG[/img]
boxx-extrude that sketch "offset from surface" selecting the object as the face you want to offset text from
[img]https://lh5.googleusercontent.com/-TMrh ... apture.PNG[/img]
[img]https://lh4.googleusercontent.com/-bfLa ... apture.PNG[/img]
boss-extude "blind" distance from the origin sketch plane
[img]https://lh6.googleusercontent.com/-KrOY ... apture.PNG[/img]
revolved boss from a line
[img]https://lh3.googleusercontent.com/-7I0m ... apture.PNG[/img]
[img]https://lh6.googleusercontent.com/-9jhB ... apture.PNG[/img]
swept boss
[img]https://lh6.googleusercontent.com/-fbyr ... apture.PNG[/img]
just a few to mention right quick
