Would it be possible to get an Orion from the factory with a smaller nozzle already installed?
Thanks.
Orion Nozzle
Re: Orion Nozzle
None of the users of this board can answer that except the owners of SeemeCNC and they may not read your message.
You should send an email to [email protected] and ask them the same question.
Re: Orion Nozzle
Ahh, I figured this was the people that worked for them given how knowledgeable they are.
Re: Orion Nozzle
Naw, we're just a bunch of ragtail Delta printer owners thrown together to try to help each other out. SeemeCNC has their headquarters in Indiana andLasivian wrote:Ahh, I figured this was the people that worked for them given how knowledgeable they are.
that is where the server for this forum resides. The owners do come on the Forum but not daily and messages sent to them via the forum probably won't
be answered. They are a great group of guys and will respond quickly once you send an email to them at the address I gave you.
Carl
Re: Orion Nozzle
Haha, I got both, your email AND the post here.
To answer, no, we don't offer the Orion's with other nozzle sizes. However, the nozzles on our site are direct fit replacements for both the Rostock MAX and Orion machines, so if you're after different nozzles, go ahead and order it with your orion, and it'll be in the box. It's easy to change, simply unscrew the old, pull the PTFE liner out, insert it into the new nozzle, and re attach the new nozzle. You'll most likely want to re-calibrate your Z height, but that's about it
