3D Printed Enclosure Mounts
bubbasnow
Re: 3D Printed Enclosure Mounts
Post by bubbasnow »
This thing is getting pretty popular, it just made an appearance on the Seemecnc facebook! Cope you should post your changes so people don't use a unimproved model.
TFMike
Post by TFMike »
How could the Orion be modded to have the spool holder on top and this thing downsized? Anyone up to try it?
jmpreuss
Post by jmpreuss »
TFMike wrote:How could the Orion be modded to have the spool holder on top and this thing downsized? Anyone up to try it?
I have my spool top mounted on my Orion, there is a post about it in that forum. Note it was easier for me since I had a pre-production that had screw holes for a top mount, most others would need to drill holes. SeeMeCNC posted the design files for the top mount on their orion github site.
int2str
Post by int2str »
I have a very easy idea for an ORION "enclosure".
The "prototype" is on my printer that's currently running.
With an ambient temperature of 20C, temperature inside the "enclosure' is around ~30C. I think that'll help with the part cool-down and hopefully prevent some ABS layer separation as it cools.
I'll try to clean up the prototype a bit going into the weekend and I'll make a post about it.
cope413
Post by cope413 »
bubbasnow wrote:This thing is getting pretty popular, it just made an appearance on the Seemecnc facebook! Cope you should post your changes so people don't use a unimproved model.
I've been slammed lately with the holidays, outside print jobs (including a massive one that I'll post pics of soon), prepping for http://www.3dprinterworldexpo.com/page. ... ch=5120_94, on top of my normal day job.
Haven't been active much, but I'll catch up with the forum activities soon...
TFMike
Post by TFMike »
Awesome, got pictures? Also did you see the private message I sent you awhile back?
bubbasnow
Post by bubbasnow »
this design linked should also work for the orion, although i do not have one so it is not tested
TFMike
Post by TFMike »
the orion is like a round triangle shape while the max is a circle at the base, right?
bubbasnow
Post by bubbasnow »
TFMike wrote:the orion is like a round triangle shape while the max is a circle at the base, right?
true, but this mounts to the arms using the 120deg angles. it should work, if not the idea should work and need to be scaled down a bit. but like i said i dont have one so i dont want to say for sure. from the pictures on the seemecnc website it should work.
bubbasnow
Post by bubbasnow »
finished my latch today
[img]https://lh6.googleusercontent.com/-myg0 ... 163110.jpg[/img]
[img]https://lh4.googleusercontent.com/-Rsh5 ... 163122.jpg[/img]
[img]https://lh6.googleusercontent.com/-Zkx8 ... 163138.jpg[/img]
the hinge axis are 6 inches, print 4 square pins, 6 round pins, 3 arms, 4 ea front and back latch. i would scale the pins x.99 or x.98.
the color change is kind of lame, but my clear t-glase was boning up. green printed way better!
latch.SLDPRT
(536.5 KiB) Downloaded 491 times
One more time, Damn good job! This is something that could be made into a kit and sold for profit...
There are so many print hours in it though.....
The panels the buyer would pick up local.
bubbasnow
Post by bubbasnow »
it was a little over 1 roll of pla. if we think of it in those terms it doesn't sound that long :) I've printed about 6 rolls since i started printing in September not counting this. this print (besides the latch) doesn't require anything fine in detail so a .7 nozzle would do this in no time.
cjdavis618
Post by cjdavis618 »
This enclosure is Fan..Freaking..tastic..
Great work!!!
enggmaug
Post by enggmaug »
Only one door ? Isn't it an issue for maintenance, calibrating and cleaning ?
bubbasnow
Post by bubbasnow »
I've taken my heat bed out with no issues. You could always add more doors if you want. To adjust end stops I have knobs installed so I can adjust by hand.
enggmaug
Post by enggmaug »
bubbasnow wrote:To adjust end stops I have knobs installed so I can adjust by hand.
I see. Great work !
Capt Jack
Post by Capt Jack »
I want to print this enclosure (bad!), but I can't open/modify .sldprnt files. Can you possibly post the joint file in .stl format?
~Capt. Jack~
Capt Jack
Post by Capt Jack »
Nevermind. Got the 15 day trial of eDrawings and converted it.
~Capt. Jack~
bubbasnow
Post by bubbasnow »
sorry i spaced out for a couple days... if you need it in a different cad format let me konw.
grabredemeyer
Post by grabredemeyer »
Did Cope end up posting his changes/improvements to this somewhere? I'd like to see what he did before I print a version of this.
bubbasnow
Post by bubbasnow »
grabredemeyer wrote:Did Cope end up posting his changes/improvements to this somewhere? I'd like to see what he did before I print a version of this.
not that ive seen :( ive been using these since this post started with no issue printed as is. only issue that i saw that could be improved upon is support where the screws go through into the wood. because not everyone would put screws in the same place i left that up who ever wants/needs to put them in.
Capt Jack
Post by Capt Jack »
How did you print the joints? Specifically, how did you lay them out on the print bed....horizontal or vertical? Just looking for the best way to print them.
~Capt. Jack~
bubbasnow
Post by bubbasnow »
Capt Jack wrote:How did you print the joints? Specifically, how did you lay them out on the print bed....horizontal or vertical? Just looking for the best way to print them.
vert hollow 3 perimeters
Capt Jack
Post by Capt Jack »
Thanks! ;)
~Capt. Jack~
dansch
Post by dansch »
wow, real great work! i was looking for a way how to prevent my rostock from becoming to dusty (in my workshop), and this seems like the perfect solution!
