Prints Stopping
printer999
Prints Stopping
Post by printer999 »
hey guys I am using a Orion and all of the sudden Whenever I print something I get a few layers in or many times less and the print just stops and the printer wont respond to repetier host unless I restart it. Someone please help. I think this may be because I now use slic3r 9.9 but even when I use Cura to get G-code the same thing happens. Please help!
DavidF
Re: Prints Stopping
Post by DavidF »
Try printing from the SD card...
Lost pla castings? see me
printer999
Re: Prints Stopping
I use a mac air without a sd card slot. I wish I could but the card reader that I bought for just that reason never worked
printer999
Re: Prints Stopping
printer999 wrote:I use a mac air without a sd card slot. I wish I could but the card reader that I bought for just that reason never worked
Well I have found the ultimate solution! yes! And now it works. I put the SD card into my gopro then plugged that into the computer no more problems now. Thanks!
DavidF
Re: Prints Stopping
Post by DavidF »
Good deal, that was surely thinking outside the box. Personally I was thinking your screwed LOL....
Re: Prints Stopping
DavidF wrote:Good deal, that was surely thinking outside the box. Personally I was thinking your screwed LOL....
As a Mac user, he should be used to it by now.
*runs*
:D
neurascenic
Re: Prints Stopping
Post by neurascenic »
I ran a long print last night and got up this morning to a print that stopped. LCD said "Killed" no other indication.
Also running off of a macbook air.
and Gene, you slight my not-so-fragile state of mind. ;)
dpmacri
Re: Prints Stopping
Post by dpmacri »
neurascenic wrote:I ran a long print last night and got up this morning to a print that stopped. LCD said "Killed" no other indication.
I run my printer from a MacBook Pro. Early on I found that the power-saving features (even when connected to battery) were causing USB disconnections and prints would stop. I've since disabled all power-saving except for the display (if you don't shut it off, it won't last as long) and haven't had any problems since.
neurascenic
Re: Prints Stopping
Makes perfect sense... Long run, I will be running off of an SD card any way. I am only doing this for setup. I don't have a USB cord long enough to connect to my Tower, so I am using my wifes MB Air. Too, no point in dedicating a 12 core Pro to printing. hmmm. Octoprint...
thanks for the insight!
Re: Prints Stopping
Yeah, power management is the kiss of death to a USB-connected 3D printer.
derwoodvw
Re: Prints Stopping
Post by derwoodvw »
I print from an sd card and a lot of my prints stop. It seems to be only on longer print jobs. I have only had it a week and this has happened about ten times. having second and third thoughts. POS!
emile1138
Re: Prints Stopping
Post by emile1138 »
I have the same problem, but I've noticed it ONLY happens when I turn on supports in Slic3r.
I'm still working on figuring it out...
Caleb Fairres
601 Sroufe Street
Suite 200 / Dock 2
Ligonier, IN 46767
(765) 884-4100
[email protected]
McSlappy
Re: Prints Stopping
Post by McSlappy »
geneb wrote: As a Mac user, he should be used to it by now.
*runs*
:D
As a mac user I laughed :)
derwoodvw
Re: Prints Stopping
Post by derwoodvw »
emile1138 wrote:I have the same problem, but I've noticed it ONLY happens when I turn on supports in Slic3r.
I posted the fix for this in another thread. If you are using the memory card that came with it, then that is the problem. You need to use a class 4 or higher card.
0rionN00b
Re: Prints Stopping
Post by 0rionN00b »
derwoodvw wrote:I print from an sd card and a lot of my prints stop. It seems to be only on longer print jobs. I have only had it a week and this has happened about ten times. having second and third thoughts. POS!
1. do not write your .gco directly to the SD card. write it to your hard drive, then copy that file over to your SD card.
2. you can read thru the .gco file prior to copying to see if it's complete or not..
Frankly after I started doing step1 above, I've never had a failed print again.
SD cards are fickle. they're cheap, unreliable, and downright trash. but they fit a purpose. Just don't trust them any more than you have to......
