After importing the slic3r settings from the download section I am having intermittent issues with the printer.
When I run the G-code produced by slic3r the machine beeps a few times, moves to begin the first layer and then the extruder runs backwards at a high rate of speed. I turn it off at this point, and sometimes when I rerun the code its fine.. other times its does the same thing.
really scratching my head here.
Suddenly Problems -G-Code running extruder backwards@hispeed
travelnaut
- Plasticator
Re: Suddenly Problems -G-Code running extruder backwards@his
I have the same problem.
Make sure that your extruders temperature is just above the setting in the gcode before you press RUN.
br
Poul
br
Poul
what firmware do you run ?
is there anything special in the GCode ?
