E1 to E0
EvilFz1
E1 to E0
Post by EvilFz1 »
i need to switch from E1 back to E0, but don't know what tab in the aurdino to find it in... also i think i blew my fuse for the extruder, its in the heat0 position, is the heat1 run off the same fuse, or can i swtich to heat1 and im good again? if so i don't know where to change that in my repetier file. thanks
AndThenSome09
Re: E1 to E0
Post by AndThenSome09 »
Configuration.h, I think they run off the same fuse though, not so sure about that
3D Printing Blog, Build, News, and Store
Come check us out @ http://www.i3dtech.net
Eric
Re: E1 to E0
Post by Eric »
One fuse is for the heat bed output.
One fuse is for the other heat and fan outputs.
One fuse is for everything else, including stepper outputs.
If any fuse is blown, you're not going to be operational. There are some creative ways to fix the fuse, but there isn't a workaround for not fixing the fuse.
