Software for .stl modification
Viro
Post by Viro »
Hi,
I have a few .stl files of adapters I have prototyped. I am wanting to make changes to them so I can print out a more complete adapter. Is there a specific software or conversion that I should be using? I am starting to think maybe having them give me the .stl isn't what I needed.
Thank you in advance for your help.
Viro
bubbasnow
Re: Software for .stl modification
Post by bubbasnow »
you can import them to solidworks but that costs $$
blender is free
bvandiepenbos
Post by bvandiepenbos »
If you only have .stl from client you are rather limited on editing it.
Autodesk 123D is free, and easy to use.
Meshmixer is good, but more for artistic mesh editing not mechanical parts. free.
Blender is good also, but I read it's learning curve is steep.
FreeCad, free open source looks powerful but confusing.
web based 3D CAD, TinkerCAD or 3dtin
enggmaug
Post by enggmaug »
I only use Wings 3D with manifold labs pluggin, because I know it, and it's free, and it just fits my needs.
I know there are some better softwares out there, but I'm not sure it's worth the hassle to change now.
It can import and tweek stls, like most other CAD softwares.
enggmaug wrote:I only use Wings 3D with manifold labs pluggin, because I know it, and it's free, and it just fits my needs.
Thanks for the reference to Wings 3D. I did not know about this software and I just downloaded it to give it a try.
enggmaug
Post by enggmaug »
Wings3d can be a bit disturbing in the begining if you know other CAD softwares, but when you get used to it, it becomes really handy.
If you have any trouble using it, feel free to ask me, I probably can help you out with it.
Wings3D does not natively include boolean operations. That can sometimes be a problem when you are used to other CAD softwares, as you will think boolean. That's mainly why I use the manifold pluggin.
I already tried other softwares, but I am not arsed going through the learning curve again, when I can do it in wings3D.
enggmaug wrote:Wings3d can be a bit disturbing in the begining if you know other CAD softwares, but when you get used to it, it becomes really handy.
Thank you for your offer to help. I am really busy at this time but I do hope to install the software and see if I can learn how to
use it. I am not familiar with cad so I have no preconceived bias for or against the software.
Sketchup doesn't support this filetype natively, but there are plugins available.
Jimustanguitar wrote:Sketchup doesn't support this filetype natively, but there are plugins available.
Do you mean that Sketchup will import an STL with the proper plugin?
JohnStack
Post by JohnStack »
I just tried the free STL Importer/Exporter Extension for Sketchup. Works ok. Haven't printed yet but will do so very soon.
Finally getting around to some of my own things!
http://dropc.am/p/KhiI1a
Yes. http://forum.seemecnc.com/viewtopic.php?f=16&t=1732
JohnStack wrote:I just tried the free STL Importer/Exporter Extension for Sketchup. Works ok. Haven't printed yet but will do so very soon.
Do you find sketchup okay for minor cad-stl work?
And what version do you use?
AndThenSome09
Post by AndThenSome09 »
Only problem is on every cad program I have ( solid works, autodesk inventor, sketch up, free cad, OpenSCAD) when u import an stl it is really unusable because it is made up of tons of triangles, no surfaces, holes, edges, etc. So an stl is not the best bet to modify a design.
3D Printing Blog, Build, News, and Store
Come check us out @ http://www.i3dtech.net
enggmaug
Post by enggmaug »
that's true, before modifying a STL, you need to do some heavy cleaning of the triangles.
neurascenic
Post by neurascenic »
formZ will do a pretty good job of cleaning up those triangles. If you post your file, I would be happy to clean them for you. At least attempt it.
Cheers!
Chris
McSlappy
Post by McSlappy »
Sketchup is OK for some stuff, I used it as my primary stl file creator for a while, but I often found myself having to trash and remake whole sections or parts of my model because of the way Sketchup like to magically create dumb geometry. You need a plugin for stl files and need to buy the 'pro' version to get boolean. For the price, look elsewhere.
3DS max has awesome boolean tools, but is pricey
Blender has OK boolean tools, they bug out often in my experience, but when they work they work well. It outputs stl files right out of the box and is free. Oh yeah, it has a steep learning curve.. I'm suprised by this considering how much time I've spent using 3d modeling packages, it still seems very odd in it's layout, selection and manipulation of objects.. Oh well, at least it's consistent.
McSlappy wrote:Sketchup is OK for some stuff, I used it as my primary stl file creator for a while, but I often found myself having to trash and remake whole sections or parts of my model because of the way Sketchup like to magically create dumb geometry. You need a plugin for stl files and need to buy the 'pro' version to get boolean. For the price, look elsewhere.
Do you have any experience with FreeCad? I don't but some say that it works okay, but it is no solidworks.
AndThenSome09
My favorite program for making one off parts for the printer I'm designing has got to be OpenSCAD! I like coding anyway but the control you have with dimensions and such is just remarkable!
AndThenSome09 wrote:My favorite program for making one off parts for the printer I'm designing has got to be OpenSCAD! I like coding anyway but the control you have with dimensions and such is just remarkable!
Openscad is a great program for you programming types but for someone like me with no programming experience is just gobbelty gook. I envy you guys that understands what
all that code means but I need the Gui version of something like 3d Cad for Dummies. My area of expertise is the electronics side. Started in the Navy as an electronics tech in the
computer side of things, great digital electronics schools in the Navy. This C and C++ leaves me bewildered so I have to find something freeware and just powerful enough to
produce 3D parts. FreeCad looks to be the best type software for me. I just need to spend many, many hours with it until I become reasonably competent.
AndThenSome09
Yeah, FreeCad seems to be pretty decent from the little bit I've used it. I have it installed on my computer but have only had it open a few times. Too bad you couldn't get SolidWorks, because it is powerful and still relatively easy to pick up and start going with it.
AndThenSome09 wrote:Yeah, FreeCad seems to be pretty decent from the little bit I've used it. I have it installed on my computer but have only had it open a few times. Too bad you couldn't get SolidWorks, because it is powerful and still relatively easy to pick up and start going with it.
I would love to have Solidworks but we all know what it costs, I am on a fixed income and can't come close to affording something like that.
McSlappy
Post by McSlappy »
No experience with FreeCAD :(
However I should have mentioned Vellum. Not sure of their stl capabilities, but it's like using Sketchup with the power of a full blown CAD program. Specifically the Vellum 3d packages like Argon.
timothysvec
Post by timothysvec »
Spaceclaim is nice.
If you're a Windows user, give DesignSpark Mechanical a try. It's based on the SpaceClaim engine and is free to use.
http://www.designspark.com/eng/page/mechanical
