dual e3d v5 mount for rMaxV1 with abs parallel 2 y axis easy
bubbasnow
Post by bubbasnow »
McSlappy
Re: dual e3d
Post by McSlappy »
Ha ha! I'm excited!
Re: dual e3d
bubbasnow wrote:ive started my dual e3d's
Are the components you printed a Thingiverse item? They look really nice.
bubbasnow
Re: dual e3d
Post by bubbasnow »
nope i made them
Glacian22
Re: dual e3d
Post by Glacian22 »
bubbasnow wrote:nope i made them
Well y'know, sharing is caring. :D
bubbasnow
Re: dual e3d
Post by bubbasnow »
gotta get it going first, they might not work well in this revision...i dont want to share something useless!
Tinyhead
Re: dual e3d
Post by Tinyhead »
Those parts look super nice.
Christian79
Re: dual e3d
Post by Christian79 »
Being a perfectionist myself, I get what you are saying. But one of the best things about a community like ours is "group development", you never know what the user population will come up with.
bubbasnow wrote:gotta get it going first, they might not work well in this revision...i dont want to share something useless!
bubbasnow
Re: dual e3d
Post by bubbasnow »
well these work so ill post the files tonight when i get home. i do have a few pix
[img]https://lh3.googleusercontent.com/-Ggvq ... 192554.jpg[/img]
This is my solution to the dual ezstruder.
bubbasnow
Re: dual e3d
Post by bubbasnow »
my first print with extruder 2 doing support
[img]https://lh4.googleusercontent.com/-2-Qx ... 235730.jpg[/img]
edge922
Re: dual e3d
Post by edge922 »
Would it be possible to mount them above for more Z clearance or is there no way to fit them that way.
Follow My Rostock MAX V2 Build in progress.
bubbasnow
Re: dual e3d
Post by bubbasnow »
edge922 wrote:Would it be possible to mount them above for more Z clearance or is there no way to fit them that way.
not with the stock effector plate :(
bubbasnow
Re: dual e3d
Post by bubbasnow »
ok here are my files
with this design follow the described order for proper installation.
1. slide both hot ends into the slots
2. snap 1 side of the fan shroud onto the collar just above the top cooling fins.
3. rotate the fan shroud until the second extruder snaps into place.
4. put the clamp over the top of the nozzles to lock them in place.
5. tighten down the ptc connectors all the way and cut the extra plastic flange off of the outside, this is a tight fit and is required to get these to not bind inside the effector plate
[img]https://lh5.googleusercontent.com/-dEyv ... 154610.jpg[/img]
6. insert screws through head before installation of the fans because they will block the holes, i use a couple tiny drops of superglue instead of screws to hold the 30mm fans in place.
[img]https://lh3.googleusercontent.com/-FJeB ... 155900.jpg[/img]
7. install the nozzles so they are parallel with the Y axis (6 holes in the effector plate this makes offset in firmware easiest).
8. if shimming is required just loosen the two screws on the nozzle that needs adjustment and insert shim between effector plate and clamp.
let me know if any additional info is needed.
another photo
[img]https://lh5.googleusercontent.com/-_sO6 ... 155914.jpg[/img]
duale3dslot.STL
(87.39 KiB) Downloaded 419 times
duale3dclamp.STL
(114.14 KiB) Downloaded 372 times
duale3dfan.STL
(899.98 KiB) Downloaded 376 times
duale3dclamp.SLDPRT
(125.5 KiB) Downloaded 398 times
duale3dfan.SLDPRT
(370 KiB) Downloaded 421 times
duale3dslot.SLDPRT
(127.5 KiB) Downloaded 388 times
Re: dual e3d
Thank you for posting the files. This is the best setup I have seen and certainly better than anything I have
seen on Thingiverse.
Re: dual e3d
What is the offset value you used?
bubbasnow
Re: dual e3d
Post by bubbasnow »
i set the offset in eeprom, if you align the nozzles with the y-axis there is no x offset.
Re: dual e3d
Thank you for posting the numbers.
bubbasnow
Re: dual e3d
Post by bubbasnow »
here is something i made real quick to test slic3r
[img]https://lh4.googleusercontent.com/-GA8F ... -no/14+-+1[/img]
Re: dual e3d
I'd say you have your dual extruders working well.
Excellent job!
bubbasnow
Re: dual e3d
Post by bubbasnow »
Printing some stuff
Sliced in s3d
Tinyhead
Re: dual e3d
Post by Tinyhead »
That's awesome! Looks super clean! Some of the other setups and results I've seen are nothing compared to what you've got running there.
0110-m-p
Re: dual e3d
Post by 0110-m-p »
That looks awesome. I'm assuming you used ABS for all the mounts? Seems like PLA that close to the nozzle/heater cartridge would warp really quick due to heat.
bubbasnow
Re: dual e3d
Post by bubbasnow »
yar it is orange abs, you could probably get away with PLA, i would just wrap the heater blocks with insulation first.
bubbasnow
Re: dual e3d
Post by bubbasnow »
alrighty so i have replaced my temp solution for the dual ezstruders with this.
[img]https://lh6.googleusercontent.com/-OLX6 ... 114447.jpg[/img]
It fits in the standard holes but i had to drill 2 for the filament to feed down. i am also using some of those filament spool rollers using nylon drawer wheels
[img]https://encrypted-tbn0.gstatic.com/imag ... D30o9k5oER[/img]
Re: dual e3d
Nice job!
Would you still have the stl for the dual ezstruder mount?
