Printer stops half way into print same place every time
kfitzhenry
Post by kfitzhenry »
It's a 7 hour print that stops about halfway every time. 4 trys, change the layer thickness from .4 to .2 then to .21 . Tried 2 different versions of Slic3r. same results
Tried print from SD card and pc. SD card is a class 10.
generated by Slic3r 1.0.0 on 2014-04-18 at 12:37:17
; layer_height = .21
; perimeters = 3
; top_solid_layers = 3
; bottom_solid_layers = 3
; fill_density = .15
; perimeter_speed = 30
; infill_speed = 30
; travel_speed = 200
; nozzle_diameter = 0.5
; filament_diameter = 1.71
; extrusion_multiplier = 1
; perimeters extrusion width = 0.50mm
; infill extrusion width = 0.98mm
; solid infill extrusion width = 0.85mm
; top infill extrusion width = 0.85mm
G21 ; set units to millimeters
M107
G28
M104 S185
M190 S55
M109 S185
; BEGINNING OF HEAD MOVEMENT WARNING TONES
M120 S4 P10
G4 P40
M120 S4 P10
G4 P40
M120 S4 P10
G4 P40
M120 S4 P10
G4 P40
M120 S4 P10
G4 P40
M117 KEEP HANDS AWAY
G4 S3
; END OF HEAD WARNING TONES
G90 ; use absolute coordinates
G92 E0
M82 ; use absolute distances for extrusion
G1 F6000.000 E-5.40000
Ghost Print.stl
(21.39 MiB) Downloaded 229 times
Re: Printer stops half way into print same place every time
Which firmware are you running?
kfitzhenry
Repetier 0.83seeme
There is a known bug in the 0.8x Repetier, where sometimes it just stops.
You've tried the usual workaround, slicing with slightly different layer heights, your best solution is probably to upgrade to 0.9.
carter
Post by carter »
I was having inconsistent printer stopping that, after three successful prints, I believe was caused by induction from the stepper motors to the LCD ribbons.
I suspect that it stopped when the printer was doing intricate patterns with frequent direction changes. Is the place where it's stopping more complex than previous layers?
kfitzhenry
I just finished install the las test firm ware and re-calibrating. Started the printer up to try again with the same file.
Will know something in about 4 hours if I have the same problem. Or success in 6+ hours.
Stay tuned
Ken
kfitzhenry
The print finished. No stoping half way. I used the same gcode I was using before I upgraded to the new firmware.
I upgraded to 0.91.
I would like thank those who gave suggestions.
Thanks....Ken
