Stock Hotend bracket rod slipping
graham.p.heath
Post by graham.p.heath »
The new hot end bracket has these short metal rods that attach everything together. One of mine is slipping, the other 2 seem stationary or to have a tendancy to slip toward the fan which blocks them from moving. I first noticed it after it had come apart. I was able to push it back in with my fingers and am now monitoring it.
I had been running the machine at 275% for at least a few hours before i noticed this.
Other than running the machine slower, anyone got an idea about this?
Re: Stock Hotend bracket rod slipping
Contact support at SeemeCNC with this one, they need to be aware that is happening and they can suggest the best remedy for this.
bvandiepenbos
Post by bvandiepenbos »
others are having same issue with the v2 platform axles walking out, see this thread...
http://forum.seemecnc.com/viewtopic.php?f=60&t=4944
my suggestion to fix issue was...
I think you could drive some short #4 self taping screws in at an angle between the little tabs that grab axle and the axle itself to prevent axle from walking out...
I have not tried this, but it is how we fasten our CF arms to the v2 platform.
Look at this picture to understand what I am talking about.
http://www.tricklaser.com/Carbon-Fiber- ... M-CFTX.htm
(the second picture on product page shows install information)
let us know if this works, I have heard others are having same problem with new v2 platform.
the screws are 1/4" long
we use these
http://www.mcmaster.com/#93406a106/=rihwng
bvandiepenbos wrote:others are having same issue with the v2 platform axles walking out, see this thread...
we use these
Brian, I am sure your solution will fix the problem but if everyone bypassed SeemeCNC support on this the support team would never know the problem
existed or the extent of it. Something like this and the new V3 Onyx not heating correctly should be reported to support so that they are aware of the
problems. Your solution is fine as a short time fix, but support should be notified.
dgriff
Post by dgriff »
graham.p.heath wrote:The new hot end bracket has these short metal rods that attach everything together. One of mine is slipping, the other 2 seem stationary or to have a tendancy to slip toward the fan which blocks them from moving. I first noticed it after it had come apart. I was able to push it back in with my fingers and am now monitoring it.
Hi All,
Just confirming the same issue here - I've been manually re-seating the metal rods on the hotend as they slipped with the massive amount of printing I've been doing lately (see - lightsabers!)
I'll fire a note to SeeMeCNC support when I get home.
Dave
bvandiepenbos
Eagle,
you are right, SeeMe does need to know. of course.
I was just providing another option for users to be able to fix it themselves, I did not mean to imply not reporting issue to SeeMe.
My fix should work long term, better than the temporary "fix" they suggested... to put a dab of superglue on one end. ;)
bvandiepenbos wrote:Eagle,
Yep, I will take your fix over a dab of superglue.
graham.p.heath
Wow, I wasnt expecting such a large number of replies. Thanks guys! I'll let you know what I end up doing..
PopolZ
Post by PopolZ »
I have the same issue with my Orion especially with the gap filling at high speed. I think I'll just glue the axle to the plastic clip.
Orion Delta Printer
3 Axis CNC router + rotary axis
Craftex B2229 Lathe/Mill combo
Shizuma
Post by Shizuma »
I had that same issue on my V1 Rostock MAX, I just printed up some little corner brackets to keep the rods from moving out, and also hold LED's.
If the rods were moving in the v1 platform assembly, that just means the screws holding the halves together weren't tightened or the u-joints are frozen to the steel shafts.
Shizuma
Post by Shizuma »
They were tightened, but I didn't really crank down on them cause then I had to deal with the plastic being distorted, take apart, re-file, put back together, hope the screws were torqued exactly the same as last time so I go the same amount of distortion, etc, I decided that it was simply easier to just put the brackets on the corners which seems to work fine since even my first print's quality was pretty good.
graham.p.heath
I did reach out to support, this is what they said:
Quote Guanu:
we are working on a new platform design but for the time being, we suggest a drop of super glue gel (thick superglue not the thin stuff) on the inside clips of the platform (the clips the ujoints press against, but not on the ujoint side if that makes sense, you want the glue on the inside so it doesnt reach the ujoints)
So it sounds like they're aware of the problem and making progress on a long term solution. I also appreciate the specific instruction on gluing.
NavyICman
Post by NavyICman »
I am also having this issue, and am noticing that my prints are sloping in the direction of the slipping rods. Has anyone else notice a reduction in print fidelity due to this? I was thinking about eliminating the plastic clips and putting wheel collars on each end of the rod like I would do for my RC model servo links.
Tim
dgriff
Post by dgriff »
Posted on a different thread:
http://forum.seemecnc.com/viewtopic.php ... =10#p39155
I applied a bit of white lithium grease to the outsides of the bearings on the metal shaft (including where they contact the effector), and the slipping has completely stopped. So far nearly a month since my "fix", and they haven't moved a bit.
Dave
graham.p.heath
dgriff wrote:Posted on a different thread:
Dave
This works!
I used this "grease" http://www.amazon.com/gp/product/B001JT8ELS/. (its a powder in a squeeze tube... wtf?)
I noticed in applying the grease that the one axle that was not slipping was already held in place by a screw, Gaunu why'd you place a screw in just the 1?
Return to “Rostock MAX v2”
