X axis falls out after good build
gajtguy
Post by gajtguy »
This happens after every good build. Grabbed the camera really quick at the end of this one. Any ideas?
Youtube: http://youtu.be/XOwbhpJ1D84
Using Slicer ver 1.0.1 No custom start/stop (I'm not that smart yet)
THIS IS THE LAST PART OF THE GCODE
G92 E0
G1 X3.989 Y-4.683 F7800.000
G1 Z11.750 F7800.000
G1 E5.50000 F6000.000
G1 X4.215 Y-4.265 E5.51696 F600.000
G1 X4.532 Y-4.092 E5.52980
G1 F6000.000 E0.12980
G1 Z11.950 F7800.000
G92 E0
M107
M104 S0 ; turn off temperature
M140 S0 ; turn off bed temperature
G91
G1 Z10 E-5. F18000
G90
G28 ; home X axis
M84     ; disable motors
; BEGINNING OF PRINT FINISHED TONES
M117 PRINT FINISHED
M120 S6 P10
G4 P40
M117 WAIT UNTIL COOL
G4 P40
M120 S6 P10
G4 P40
M120 S6 P10
G4 P40
M120 S6 P10
G4 P40
M120 S6 P10
G4 P40
; END OF PRINT FINISHED TONES
; filament used = 6056.1mm (14.6cm3)
Re: X axis falls out after good build
If your using Repetier Host there is an option in the printer setup to goto the dump area at the end of print, my guess would be it's set, you want it disabled.
gajtguy
Post by gajtguy »
Is the setting you are referring to: Go to Park Position after job/Kill (Repetier v.95F)
But why turn it off? Sounds like a desirable setting and if it just doesn't work, has this been reported as a bug? By multiple people? How can we help get it corrected?
It has no place or use in a Delta printer. That's why the instructions tell you to turn it off.
