dual e3d v5 mount for rMaxV1 with abs parallel 2 y axis easy
bubbasnow
Re: dual e3d
Post by bubbasnow »
Eaglezsoar wrote:Nice job!
Would you still have the stl for the dual ezstruder mount?
i have a tiny revision i need to make before i share :) stay tuned
bubbasnow
Re: dual e3d
Post by bubbasnow »
ok here ya go
dualextruder.SLDPRT
(762 KiB) Downloaded 350 times
dualextruder-Boss-Extrude2.STL
(451.74 KiB) Downloaded 370 times
dualextruder-Boss-Extrude3.STL
(1.99 MiB) Downloaded 385 times
Re: dual e3d
bubbasnow
Re: dual e3d
Post by bubbasnow »
Alright so with dual extruders comes....printed then dissolved support material.
[img]https://lh4.googleusercontent.com/-AC_K ... 191314.jpg[/img]
[img]https://lh4.googleusercontent.com/-jg_i ... 191319.jpg[/img]
[img]https://lh3.googleusercontent.com/-GZtZ ... 191431.jpg[/img]
Tinyhead
Re: dual e3d
Post by Tinyhead »
I've always been curious to see just how clean the print comes from the dissolving.
Looks like you've got things pretty figured out with the dual setup. That cube looks pretty tight!
bubbasnow
Re: dual e3d
Post by bubbasnow »
[img]https://lh4.googleusercontent.com/-KCAs ... 184521.jpg[/img]
ramus from league of legends
Prozac
Re: dual e3d
Post by Prozac »
Awesome that support looks fake in that image like it was photoshop'd for some reason , maybe thats because its kinda floating off the object , either way cant way to see the cleaned up version. And whats is it btw , spiked helmet for Doomsday preparation , lol. Hmmm.
bubbasnow
Re: dual e3d
Post by bubbasnow »
bubbasnow
Re: dual e3d
Post by bubbasnow »
bubbasnow wrote:Alright so with dual extruders comes....printed then dissolved support material.
Alright so an update to this cube.
i had found some 95% tech grade d-limonene locally.... and after 4 days this is the progress
[img]https://lh5.googleusercontent.com/-9C2N ... 131743.jpg[/img]
[img]https://lh5.googleusercontent.com/-xdVv ... 131733.jpg[/img]
I think the fact that its 95% TG, instead of the recommended 97% FoodGrade has a little to do with how slow it dissolves, but what is having a more direct affect is the fact that the supports were printed as a solid instead of a typical support structure. The rammus i showed in a earlier post should disolve much faster because of the ammount of exposed surface area of the HIPS.
or this f16 that is about done
[img]https://lh6.googleusercontent.com/-lz2q ... 132431.jpg[/img]
[img]https://lh3.googleusercontent.com/-GWdH ... 132443.jpg[/img]
bubbasnow
Re: dual e3d
Post by bubbasnow »
JohnStack
Re: dual e3d
Post by JohnStack »
I assume you're going to hand finish the rest! Looks very cool. You're a pioneer!
http://dropc.am/p/KhiI1a
Re: dual e3d
Looks like a great way to add and remove support structures without damaging the part.
gestalt73
Re: dual e3d
Post by gestalt73 »
Hey Bubbasnow,
This may seem like like a strange question, but have you noticed a difference in surface finish/alignment/quality when mounting the E3Ds under the print carriage like that?
I seem to remember getting really clean prints before I upgraded and mounted the E3D underneath the print carriage. Now my external perimeters aren't quite as clean as they were before. They're not bad, but they're not perfect anymore either. I'm trying to track down the cause.
I'm going to remount a single extruder high in the carriage again to see if that's the cause. If it is, I guess I'll need to design another carriage where I can mount the duals high instead of low.
bubbasnow
Re: dual e3d
Post by bubbasnow »
i have not seen this, but i can see how it could be a problem
nitewatchman
Re: dual e3d
Post by nitewatchman »
I think that this may be the result of the gimbaling effect of the effector platform. If the platform can we wiggled about the vertical axis the centerline of the extruder can be made to rotate in a slight arc realitive the the part Z-axis.
If the tip of the extruder is on the face of the platform (not practicle from a clearance srtandpoint), the rotation occurs about the tip and there is no side to side motion since the radius to the tip of the extruder is essentially zero. If the tip is moved away from the platform the radius increases and the side to side motion for a given angle of rotation increases.
This may increase the alignment error or maybe not. On second thought just ignore this post and strike it from the record.
nitewatchman
gestalt73
Re: dual e3d
Post by gestalt73 »
Actually nitewatchman, that's what I've been wondering.
Knowing that every discrete position is only an approximation, there's going to be a small error in every position and movement, and any error in position or angle of the effector plate would be magnified the farther away you get from the carriage.
I suspect that for every motion there is a very slight tilt one direction or another, which wouldn't be important with a standard mount, but would stand out more on the low mounted hot end.
I'm going to switch back to a single extruder high mount and see if I notice a difference. I should be able to get to that this week.
I'll print out a pair of parts with the same settings and compare.
bubbasnow
Re: dual e3d v5 mount for rMaxV1 with abs parallel 2 y axis
Post by bubbasnow »
updated title of post to make this more clear..
JohnStack
Post by JohnStack »
bubbasnow wrote:updated title of post to make this more clear..
And the bromance continues!!!
bubbasnow
Post by bubbasnow »
THEY made me do it
