man sized
Re: man sized
i made these, i used some carbon fiber arrow shafts i got from a sports store. Im using s3d, no retractions, no lifts and going slow.
Re: man sized
Would it be possible to get the STL file that S3D created and the outside diameter of the arrow shafts? Thanks Bubbasnow.bubbasnow wrote:i made these, i used some carbon fiber arrow shafts i got from a sports store. Im using s3d, no retractions, no lifts and going slow.
Re: man sized
the arrow shaft is .3"
the system i am using is like a retaining sleeve to hold the magnet in.
[img]https://lh3.googleusercontent.com/-smvX ... 142043.jpg[/img]
[img]https://lh4.googleusercontent.com/-Ce-4 ... 142132.jpg[/img]
[img]https://lh5.googleusercontent.com/-uXVp ... 142202.jpg[/img]
[img]https://lh4.googleusercontent.com/-tQy0 ... 142220.jpg[/img]
[img]https://lh4.googleusercontent.com/-ajRv ... 142255.jpg[/img]
[img]https://lh6.googleusercontent.com/-GFTD ... 142247.jpg[/img]
- ring.STL
- (51.25 KiB) Downloaded 435 times
- magholder1.STL
- (271.18 KiB) Downloaded 361 times
Re: man sized
Excellent, just what I was looking for. Thank you so much.
I have one more question before you get mad enough not to talk to me again.
Is the effector you show one of the ones that has been posted on the forum or is it your design?
You already know what my next question will be, the STL. Thank you Bubbasnow.
Re: man sized
Not posted yet. I haven't finalized anything yet
Re: man sized
Thanks for the other files!bubbasnow wrote:Not posted yet. I haven't finalized anything yet
Re: man sized
note that these are for this 'man sized' printer not rostockMax
Re: man sized
Noted, but the rod ends will work with the proper effector for the Max, and what I was looking for is the rod end thatbubbasnow wrote:note that these are for this 'man sized' printer not rostockMax
I could print correctly. I have been having a bear of a time printing the rod ends that would fit the Traxas balls.
Re: man sized
and progress
[img]https://lh5.googleusercontent.com/-AxLG ... 002640.jpg[/img]
yup thats a yard stick on the build height, soon ill hook up the electronics and get to cracking with linuxCNC on my BBB
Re: man sized
Bubbasnow - What cape are you going with on this? I just ordered a CRAMPS PCB and intend to populate it later on when I get around to building my very own "man sized printer" like yours. Basically I'm gonna emulate ya. Would you mind sharing files etc with me later if and when I get everything soldered together and tested?
Re: man sized
i got a bebopr plus plus, yea once i get this thing dialed in ill post my stuff
Re: man sized
You should glue the yardstick on permanently; it's an interesting trim piece, plus answers the first question about size. Besides, it could be handy for measuring the odd item.
Re: man sized
I'm a bit glad to see now that the printer isn't as gigantic as I once thought it was. In the first pictures, the effector arms looked crazy long and flimsy, but the later pictures/video now looks like an oversized kossel. To me the original was humongous... but now it looks reasonable. Looks good too. Can't wait to see what it's capable of.
Re: man sized
It's alive!
Why did you mount the limit switches so low? It looks like you have more height available.
Re: man sized
Purely for test.. I didn't want the carriage blowing past and ramming the top of the frameEric wrote:It's alive!
Re: man sized
important dimensions
[img]https://lh6.googleusercontent.com/-Ji_7 ... 223944.jpg[/img]
all together
https://plus.google.com/112937153117031 ... SpSdjZpi6Q
movement with linuxCNC and BBB w/BEBOPR++
all together
- Demolishun
Re: man sized
That looks awesome dude!
Please give us final dimensions on build area. I might want to duplicate this. Again, awesome work. It looks very beautiful.
Re: man sized
rethinking the endstop adjustments
[img]https://lh5.googleusercontent.com/-Wdwa ... 121916.jpg[/img]
- barry99705
Re: man sized
bubbasnow wrote:rethinking the endstop adjustments
Now that's cool!
- Renha
Re: man sized
I can't see anything, youtube says it's private video
3D printing is magic!
Re: man sized
Getting things dialed in....: http://youtu.be/ASnN7lhQbBQ
Re: man sized
I can't see it but geesh, you are the maker I want to be...
http://dropc.am/p/KhiI1a
Re: man sized
The video is Private. Can you fix it so we can watch it? Thanks!bubbasnow wrote:Getting things dialed in....: http://youtu.be/ASnN7lhQbBQ
