I'm just about finished with my Rostock Max V2 build.. putting the acrylic panels on and I noticed to sets of red and black wires (maybe 22 gauge)... one is tied and the other twisted.. but neither are connected to anything up top.. and I remember atttaching them to my RAMBO at the button. What am I supposed to do with these wires??
Edit: Just figured out they are the 26 gauge wires for the two extra fans. What should I do with those fans? Thanks for your help!
**SOLVED** 2 Sets of Red and Black Wires Not Connected
FDM_Process
Re: Help (2 Sets of Red and Black Wires) Not Connected
Follow the build instructions, you will eventually print your two fan shrouds in ABS. Then you can wire them up. I'd recommend getting some quick connectors rather than solder them. I've had my hot end off at least a dozen times in the past couple of months.
FDM_Process
Looks like I jumped the gun on that one. Thanks for your reply though.halotosis wrote:Follow the build instructions, you will eventually print your two fan shrouds in ABS. Then you can wire them up. I'd recommend getting some quick connectors rather than solder them. I've had my hot end off at least a dozen times in the past couple of months.
