heat bed on upon power up
EvilFz1
Post by EvilFz1 »
new Rambo, uploaded repetier file into arduino, and then into eeprom... why does the bed auto turn on upon powering up the printer? what file do I need to look at to change this. the last time I was using this printer, I would manually turn the bed on from my manual control...
Re: heat bed on upon power up
It should not do that. Assuming you didn't change the suggested SeeMeCNC firmware and you have the wiring correct, you probably need to talk to support.
EvilFz1
Post by EvilFz1 »
this is support isn't it :D ... also my lcd is all solid blocks?
EvilFz1 wrote:this is support isn't it :D ... also my lcd is all solid blocks?
This is an end user forum, sometimes people from seeme actually read it and respond, but you contact them either via the chat on the website, via email or phone them all the contact info is on the main website.
Either you don't have the right firmware on the board, the wiring is bad or you have a bad RAMBO board or LCD.
PowderLab Drew
Post by PowderLab Drew »
The only time I have ever seen all blocks is when the wrong firmware was installed, or not installed at all.
