[img]http://i.imgur.com/WAAeX92.jpg[/img]
Is the hot end too close to the board?
or is the plastic not sticking well enough?
more elmers disappearing glue?
thanks for the help!
[Solved] My first print failed - what's going on?
- jeffhuber
Rostock max v2 with e3d v6
Re: My first print failed - what's going on?
Your Hotend is too low, looks like it's pretty much scraping along the build plate, this will cause the espxtruder to eat the filament.
When you set your Z Height, everything needs to be up to temperature.
- jeffhuber
That solved it! Thanks Polygonhell!
