Can anybody tell me what slic3r setting is causing this to move back and forth when retracting?
10 sec video showing the issue:
https://www.youtube.com/watch?v=KbyHbmg ... oWGPojCJFw
Cheers.
Slic3r retraction settings issue
Re: Slic3r retraction settings issue
sabretoothnz wrote:Can anybody tell me what slic3r setting is causing this to move back and forth when retracting?
Cheers.
thats the wipe setting....
Lost pla castings? see me
sabretoothnz
- Noob
Right that's what I thought. But it is disabled. At the bottom in the gcode it says wipe = 0 . I'm using Slic3r 1.1.7 Stable
Cheers
; avoid_crossing_perimeters = 0
; bed_size = 280,280
; bed_temperature = 20
; bridge_acceleration = 0
; bridge_fan_speed = 100
; bridge_flow_ratio = 1
; brim_width = 0
; complete_objects = 1
; cooling = 1
; default_acceleration = 0
; disable_fan_first_layers = 1
; duplicate_distance = 6
; end_gcode = M104 S0 ; turn off temperature\nM140 S0 ;\nM106 P1 S0 ; Turn Off PLA fan\nM42 P6 S0 ; TURN OFF PEEK FAN\nG28\nM84 ; disable motors
; external_perimeters_first = 0
; extruder_clearance_height = 20
; extruder_clearance_radius = 20
; extruder_offset = 0x0
; extrusion_axis = E
; extrusion_multiplier = 1
; fan_always_on = 0
; fan_below_layer_time = 60
; filament_diameter = 1.75
; first_layer_acceleration = 0
; first_layer_bed_temperature = 20
; first_layer_extrusion_width = 250%
; first_layer_speed = 30%
; first_layer_temperature = 210
; g0 = 0
; gcode_arcs = 0
; gcode_comments = 0
; gcode_flavor = reprap
; infill_acceleration = 0
; infill_first = 0
; layer_gcode =
; max_fan_speed = 100
; min_fan_speed = 30
; min_print_speed = 5
; min_skirt_length = 0
; notes =
; nozzle_diameter = 0.5
; only_retract_when_crossing_perimeters = 1
; ooze_prevention = 0
; output_filename_format = [input_filename_base].gcode
; perimeter_acceleration = 0
; post_process =
; print_center = 3,-4
; resolution = 0
; retract_before_travel = 3
; retract_layer_change = 1
; retract_length = 5
; retract_length_toolchange = 15
; retract_lift = 0.2
; retract_restart_extra = 0
; retract_restart_extra_toolchange = 5
; retract_speed = 60
; skirt_distance = 5
; skirt_height = 1
; skirts = 2
; slowdown_below_layer_time = 15
; spiral_vase = 0
; standby_temperature_delta = -5
; start_gcode = G28 ; home all axes\nG1 Z300 F3000 ; lift nozzle\nM42 P6 S180; TURN ON PEEK FAN (FAN1)\n;M106 P1 S80; Turn on PLA fan
; temperature = 200
; threads = 2
; toolchange_gcode =
; travel_speed = 200
; use_firmware_retraction = 0
; use_relative_e_distances = 0
; vibration_limit = 0
; wipe = 0
; z_offset = 0
; dont_support_bridges = 1
; extrusion_width = 0
; first_layer_height = 0.35
; infill_only_where_needed = 1
; interface_shells = 0
; layer_height = 0.3
; raft_layers = 0
; seam_position = aligned
; support_material = 0
; support_material_angle = 0
; support_material_enforce_layers = 0
; support_material_extruder = 1
; support_material_extrusion_width = 0
; support_material_interface_extruder = 1
; support_material_interface_layers = 0
; support_material_interface_spacing = 0
; support_material_interface_speed = 100%
; support_material_pattern = rectilinear
; support_material_spacing = 2.5
; support_material_speed = 30
; support_material_threshold = 45
; bottom_solid_layers = 3
; bridge_speed = 30
; external_perimeter_speed = 80%
; extra_perimeters = 1
; fill_angle = 45
; fill_density = 20%
; fill_pattern = rectilinear
; gap_fill_speed = 30
; infill_every_layers = 1
; infill_extruder = 1
; infill_extrusion_width = 0
; infill_speed = 30
; overhangs = 1
; perimeter_extruder = 1
; perimeter_extrusion_width = 0
; perimeter_speed = 30
; perimeters = 3
; small_perimeter_speed = 30
; solid_fill_pattern = rectilinear
; solid_infill_below_area = 5
; solid_infill_every_layers = 0
; solid_infill_extrusion_width = 0
; solid_infill_speed = 30
; thin_walls = 1
; top_infill_extrusion_width = 0
; top_solid_infill_speed = 30
; top_solid_layers = 3
Cheers
; brim_width = 0
; cooling = 1
; fan_always_on = 0
; g0 = 0
; gcode_arcs = 0
; infill_first = 0
; layer_gcode =
; notes =
; post_process =
; resolution = 0
; skirt_height = 1
; skirts = 2
; spiral_vase = 0
; temperature = 200
; threads = 2
; wipe = 0
; z_offset = 0
; raft_layers = 0
; bridge_speed = 30
; fill_angle = 45
; infill_speed = 30
; overhangs = 1
; perimeters = 3
; thin_walls = 1
